closetmodeller
Greystones Model Railway Layout.
With the assistance of Eoin Murray, I have commenced a bench-top layout [out and back], loosely based on Greystones Station. This is the only part of the Dart which is an electrified and single track main, hence my interest. The photographs show work in progress.
I am indebted to Dave Lindfield for the construction of the baseboard.
The Dart.
The newly completed baseboard.
Photocopied templates used to determine layout.
Edited by closetmodeller
Share this post
Link to post
Great start. Looking forward to seeing this one develop.
The MRSI had a layout of Greystones a few years ago which was impressive. I think it sadly no longer exists, however someone from the MRSI may have some photos of it ect which could be of use to you. :tumbsup:
Share this post
Link to post
Hi
And so does the station design, here is closetmodeller's sketch of Greystones station hot off the scanner ready for CAD to make the templates to cut out the platforms and do the other stuff;-
Eoin
Share this post
Link to post
Great stuff. I've a particular interest in your project as I live in Greystones. I am going to do a new layout soon and I'm thinking of using part of the Bray/Greystones route in the layout, particularly the caves.
Share this post
Link to post
Hi Ray
Bray Head layout would be a fascinating project, I've done some preliminary sketches of the like, very hard to scale down at OO gauge to fit in a home layout but would be amazing;-
You should consider the Modular Layout System for this;- http://irishrailwaymodeller.com/showthread.php/2465-Modular-OO-Layouts?p=37052&viewfull=1#post37052
Eoin
Share this post
Link to post
Hi
We did our station site inspection today- of all gloomy days!
Here is closetmodeller carrying out the station platform tarmac survey- way, way off in the distance. There is a kind of old style black & white quality to this photo?
The station building is very nice but suffers from inconsiderate placement of ducting, signs and all kinds of stuff, though necessary for the running of things but badly thought out!
A bit of maintenance wouldn't go a miss
Eoin
Share this post
Link to post
Hi Eoin,
I don't have the room so I am thinking of copying a couple of the tunnels and part of Bray Head. With your DART that I ordered I think it would look amazing.
Hi Ray
Eoin
Share this post
Link to post
Hi All
Here are a few photos of progress, track is now down and points wired, though a few kinks to be sorted. The sod has been cut and the station platforms, the road bridge and the timber yard foundations are installed. There is a hold-up area behind the timber yard screen through the road bridge- that's the track on to Wicklow town!
Eoin
Edited by murrayec
Share this post
Link to post
Looks great, the walls embankments and bridges ad a great dimension to the layout. Paudie the bridge, walls, platforms are all made from foam cut with a hot wire cutter. Eoin is a master at it.
Share this post
Link to post
What material did you use to make the platforms, bridges and walling . Looks great. Is it available?
Paudie
Hi Paudie
As Dave says- it's foam- Woodies best- I use standard aero-board insulation for flat stuff like the platforms and building up under things, it comes in all thickness's up to 50mm. Then the pink stuff is polyester roof insulation, its very similar to art foam (the blue stuff) but half the price- its used for detail and structures, its much stronger and comes 60mm thick and it can be cut down to slivers of .5mm.
All cut with hot wire cutter on a board with a few straight edges, set-square, and paper templates from the drawings pinned to the foam.
Ventilation is a must when cutting and stay away from the Kingspan stuff- nasty black smoke!
I can post a picture of the set-up if you like
Eoin
Share this post
Link to post
Hi Paudie
No need for plaster, unless you want, I usually use PVA or MDF sealer straight on the foam then undercoat and apply scenic. Where the model may get a bit of ware and tare one can use a hessian material with a few coats of PVA, it gives a very strong reinforced plastic finish to the surface.
Eoin
Share this post
Link to post
Hi
Here is a small update on Closetmodeller's Greystones Layout, work has been progressing slowly but we are having fun;-
Track is finally down with the ballast now to be completed
Blue sky painted in and everything under-coated
Closetmodeller cut and mounted the preliminary drawing of the station building to get an idea
Finally Closetmodeller's vintage steam loco!
Eoin
Share this post
Link to post
I'd be interested in that when you get a chance, Eoin
Share this post
Link to post
Progress on Greystones Station scenics proceeds.
The model is very loosely based on Greystones. Obviously, much remains to be done. Wiring has been converted from analogue to digital control.
The master modeler himself does the paintwork. Grassing and greenery are the next tasks.
Beach being prepared for water and sanding.
View to the South, showing road bridge and rock formations.
Share this post
Link to post
Some additional work on developing scenics
The sea shore grows
foothpath through sand dunes
141 sits on ramp to "timber yard". The blue item is a 3D printed IE buffer, placed on track for comparison purposes.
Panoramic view of beach, etc.
The trial 3D printed buffers. [i had only blue "ink"!]
Cliff and bridge separating "timber yard" from storage area.
Share this post
Link to post
