Lenz BM1
Gearóid
Hi Folks,
have learned a lot from the forums, however this is my first post to any of the forums. I am currently testing ABC with a Lenz BM1. I have a Jinty fitted with a ZIMO MX648 decoder, CV 27 with bit 0 set to 1 and it works fine, slows down and stops and I can reverse it away. However, my 071 fitted with the Loksound 4.0 and again CV 27 bit 0 set to 1 works fine, slows down and stops but, for some reason the 071 wont reverse when I try to get it to reverse. If I reset CV27 to 24, default setting, reverse mode is re-activated. Your help would be appreciated.
thanks
Gearóid
9 answers to this question
Folks,
I think DV is correct I have just checked the Loksound 4.0 pdf Instruction manual Murphy Models «Class 071 / 111 and Cvs 51 -56 are to do with load control. 27 is indeed Brake Mode. I did try what you suggested DC but to no avail. For that reason I looked up the PDF on the web. Thanks anyway.
Answer this question...
