GSR Class 551 / J26 ECMbuild in 7mm
murrayec
Break gear coming together
Shoes cut out of Delrin for insulation purposes and the hangers from .5mm brass
Hangers marked out and holes drilled ready for cutting out
All the bits, including guard irons from .5mm brass, the fire grate front n sides and a little bit of grate detail in .5mm brass with rivets punched
Break shoes pinned onto the hangers, 1.2mm brass tube with .6mm id soldered into the chassis to take .6mm pins to hang the breaks off
Breaks test erected and joy-rigged at the lower end to work out the longitudinal break lever arms and cross fittings..... next
Eoin
Edited by murrayec
  • WOW! 2
  • 2 years later...
Just noticed when looking over this thread, after a long time, I describe the material for the break shoes as 'Delrin' it's not! it's Tufnol, a great material for the modeller. Made from wood/paper, it has great structural qualities, easy to be worked and can be machined.
Eoin
Eoin
When I had a 'real' job, these materials were in widespread use We also had Paxolin and Permali, plus quite a few other more 'modern' composite materials.
Permali was particularly nice - resin impregnated beechwood plies. It is fantastically tough - and takes a beautiful finish.
Tufnol always struck me as a sort of artificial boxwood substitute, in the way that its properties were not directional at all, and it was so 'fine-grained' that almost any size/shape combination would be OK.
Yes. Little known fact that the Dubliners’ hit ‘the hot asphalt’ was originally titled ‘the hot Tufnol’....
’And if it doesn’t last for ever sure I swear I’ll eat me hat’....
kudos for a connection to Dave Gorman, though. And I have been looking up Tufnol to make brake blocks - laminating brass ones right now which I hate!
Edited by Galteemore
4 hours ago, murrayec said:
I can just see you now- sitting around the billy can slurping the tae and swapping Tufnol jokes🤣 those were the days.......
Eoin
He once had a twenty minute violent agreement with a chap, until I could stand no more and shouted at them until they finally understood that they were both saying exactly the same thing, but from opposite directions.
There is an amusing materials-based story involving asbestos, but I'll have to tell you that verbally one day, as it's not suitable for a public scenario...
  • Funny 2
