burnthebox
Irish modelling site
Hi btb
A very small unit if you plan to do a lot of painting, you'd be far better off getting something a bit bigger in the compressor area. Here is a link to the kind of unit I use;- https://www.expotools.com/acatalog/AB603-Airbrush-Deal-AB603.html#SID=2
Lidl do a full size tanked compressor from time to time for around €100.00, one would need a filtration system €20.00 in Lidl (not the best unit- SIP do one for around €100.00) Lidl's one does work, it's a water filter n oiler- the oiler you don't need for painting! then the spray gun and a few connectors. These compressors are OK quality and you have the added advantage for use in other applications- pumping up her tyres!
Eoin
Share this post
Link to post
Hi Eoin, & many thanks, I should gave said what I've put in to my original opening comment about this site, I was just wondering if anyone had any info about it, & no I wouldn't be using that airbrush or any other one as I know my limits...!!!😀
BTB
Share this post
Link to post
2 hours ago, burnthebox said:
Hi anyone on here, ESP. In Cork area know anything about this, or this web site,  there  based in Middleton,
BTB
http://www.hobbymad.ie/super-detail-airbrush-set-2360-p.asp
Hi Paul.
I used one of these £77 TC88T compressors which as a moderate sized 3L reservoir and 1/5hp, so the motor is off most of the time because you are drawing air from the tank rather than direct from pump.  You would need to add a hose and airbrush. Think they also do kits including compressor and airbrush. I used an original Veda 134S, but apparently the Veda guy didn't file his trademark and there are now a few of rip-offs of poor quality, so BartSharp have launched their own range comparable to the Veda.
Compressor: https://bartsharp.co.uk/index.php/compressors/airbrush-compressors-and-complete-kits/tc88t-airbrush-compressor.html
Airbrush: https://bartsharp.co.uk/index.php/bartsharp-airbrush/bartsharp-airbrush-130-dual-action-gravity-feed-airbrush.html
Having a compressor with an air tank has been useful for me. Hope this helps.
Noel
Edited by Noel
Share this post
Link to post
15 minutes ago, Noel said:
Hi Paul.
Noel
That's a nice set up at handy money........
Share this post
Link to post
Yes I've only had it a year, but so far so good.  It has a moisture trap and the size of the tank makes using it almost silent most of the time.  I got the setup on Richie's recommendation and was very happy with it despite my recent boo-boo which turned out to be self inflicted.
Share this post
Link to post
I Bought  Set off Ebay a Few Months Bck.Compressor + Tank,Air Hose & 2 Airbrushed Set.I Think Startin up The Project off Sprayin my own Models & It Starting 2 Cost More Than What I Thought It Would.4 Set of Lifecolours Panits of 6,Thinner, Cleaners.Satey Items 2 Get Nxt.😔😕😅😄😁imageproxy.php?img=&key=ac96cff20d889157b-4 I Start Mt Sprayin.
Edited by Rails_of_Belfast
Share this post
Link to post
I live near midleton and have never heard of them, so they must be just starting up. Best of luck to them hope it works out.
Share this post
Link to post
