Fowler4f Posted May 28, 2023 Share Posted May 28, 2023 Has anyone painted a CMX Track Cleaner ? Which paint type would you use, brush rather than spray ? TIA. Quote Link to comment Share on other sites More sharing options...
Galteemore Posted May 28, 2023 Share Posted May 28, 2023 If it’s brass, as it appears, you’d have to at least rattle can it with primer. Would be as easy to spray it with a topcoat then. Not sure I’d attempt that with a brush (except maybe discrete parts like buffer beams). 1 Quote Link to comment Share on other sites More sharing options...
Fowler4f Posted May 28, 2023 Author Share Posted May 28, 2023 1 hour ago, Galteemore said: If it’s brass, as it appears, you’d have to at least rattle can it with primer. Would be as easy to spray it with a topcoat then. Not sure I’d attempt that with a brush (except maybe discrete parts like buffer beams). It is Brass, maybe best to mask the working parts underneath and bogies. 1 Quote Link to comment Share on other sites More sharing options...
