Admin
Administrators-
Everything posted by Admin
Following a little bit of spam, all new registrations are now human moderated. This might cause a small delay if you register in the middle of the night GMT This also prevents multiple accounts per IP, etc. so should be for the good of the community!
Free blogs now come as standard with every account! http://irishrailwaymodeller.com/blog.php Track the progress of your layout in a thread, or a blog - your choice !
You can view the page at http://irishrailwaymodeller.com/content.php/113-About-this-site
The twitter account has now been 'plugged into' the board, so once an hour it will update with the latest posts to keep you up to date!
https://twitter.com/#!/irishrailwaymod Will be used to track announcements and key bits of news (and also if for any reason there is a problem with this server, we'll update twitter to let ye know!)
And coverage of the approach to move it back to Malahide: Still some efforts to get it to go that way - http://www.fingal-independent.ie/news/committee-to-approach-bus-eireann-3040208.html
Listen to the podcast/,p3 from the Live Line Programme which discussed: http://www.rte.ie/podcasts/2012/pc/pod-v-08031216m39slivelinerailway-pid0-999744.mp3
Murphy Models 071 - New, detailed pre-production photos added!
Admin replied to Admin's topic in Irish Models
from Railway Pictures website -
[h=1]Adjustment to the yards[/h] April 2, 2012 | Layout Build After seeing everything down, the yard area of the terminus is being tweaked slightly. The Ballast area has been lengthened to 4.5 feet with two small sidings for tampers / per way equipment to stable. The long siding can then be used for ballast hoppers / autoballasters to be filled by digger. The depot has also been ‘rationalised’ with a simplified track plan, single road running shed and washplant added anda depot crane added to the bottom siding. The changes mean a ‘proper’ looking 12-15cm gap between the depot lines and the mainline at bottom…
With a little help from some Thomas engines and two little engineers Probably too much clutter above…. Carriage sidings… The centre three roads are the freight sidings…. Looking back into the depot (the two lines on the right are the mainline) Behind the depot, a small row of Georgian terraces and a derelict factory Peco depot shed anyone? Looking across the freight sidings towards the carriage sheds.. Slightly aerial view Ignore the rolling stock The reason for a TGV, Gordon, James and Virgin mk3′s sharing the layout
.. and the freight and ballast/per way sidings get cut and joined and pinned down to verify clearances.
To get a little break from wiring, finding shorts and to also try and resist the temptation to ‘play trains’ on the terminus section, I decided to ‘mock up’ the track on boards 3 and 4. On this side (from rear to front) there will be three Coach sidings / train storage, a 2 road ballast bank / per way storage siding, a three road freight terminus as well as a small depot.
It’ aliiive! It might not look much, but those lit LED’s are very exciting Here are two videos I took to prove it’s now actually live! 8208 Takes a spin… And Veissmann’s new P&T Tamper tries to tamp imaginary ballast
Power bus now done for the terminus district.
Having gotten a feel for how long jobs are likely to take now, I thought I would set out the roadmap of what I hope to cover / achieve in the next 6-8 weeks. - Complete the Main power bus for the Terminus District - Installation of a DPDT (Double Pole, Double throw) Switch and Programming Track connector, which will isolate the front siding of the running shed sidings and allow me to switch between running track and programming track (so I can drive a loco onto the track, switch, and programme / work on it, then switch back and drive it out ) - Installation of 14 Cobalt slow action motors, controlled by Cobalt Motor decoders on a dedicated Accessory Bus (again zoned into a district for the terminus) and correctly power routing all the frogs (the double and single slips will probably warrant entire posts on their own!) - Installation of Lighting around the running shed. I have some surface mount LED strips which I plan to use to light the Peco pit, and the shed itself, as well as adding a small tower light out front of the shed. - Installation of Peco concrete platform edging, clearance tests (again) and platform creation. - Concrete hard-standing at running shed. Once the above is complete, and assuming I can resist playing trains at that point too much, the plan is to lay the mainline on these boards and commence the mainline ‘district’ power bus, before moving to starting on boards 3 and 4, which are home to the carriage sidings, ballast bank, freight terminal and motive depot. Longer term plans include Signalling, Occupancy detection and computer control / automation of routes… watch this space! Any questions, please comment!
Still probably another days work on boards 1 and 2 just for the power droppers. Then on to the frogs and motors. Once I have all the power droppers in I should be able to do some limited testing with a loco.,.
Just need to wire it all up now!
Have a nice forest of droppers growing under the board and am powering the points directly now for ideal running.
I’m about half way through all the droppers for boards 1 and 2 and the point adjustments and pre-drilling for cobalts….. At least my soldering is improving slightly with practice!
45 Droppers cut to length, and some initial soldering tests! I am also soldering the Proses Buffer stops to the adjacent rails, to ensure a good connection, and have started breaking some peco points!
Here is a step-by-step guide for installing an inspection pit under the running shed. First, the pit is glued together as per peco instructions, and then measured up in place. The Woodland Scenics foam is cut away with a blade and the four corners drilled out with an 8mm wood bit to make room for the jigsaw. Next, cut the slot with the jigsaw (observing safety ) Once done, pop the pit in an ensure a good fit. You might need to trim or file a bit here. Next, remove the web from the back of the track for this section, just cut the web and you can pop the ties off the track for this length, and then slide the remaining web/ties off the track – you’ll need to keep it to re-thread onto the rails in a bit. Now, carefully thread the rail onto the pit, feeding it all the way through, and then thread the rail back on to the end piece of tie / web. And it’s done Doing it this way also means you maintain good electrical connectivity throughout, leading to less stressful running later on
The track on boards 1 and 2 is now cut and laid and held in place with tacks. The plan now is to install a Peco Inspection pit under the running shed, and start soldering droppers to the rail undersides on every single piece of track. I will then work on the points, removing the springs and perhaps replacing some of the more visible points sleepers with copperclad. More on that soon – here is the latest view:
