DCC Controller Wireless
Piko Dcc Smartcontrol  Wlan
Brand new in the box
150    plus post
• Ergonomic hand controller: Model railway operation should be fun! That is why good and
long-lasting usability of the hand controller is important! The PIKO SmartControlleran has exactly
the right shape and an ideally balanced weight for optimal gaming fun! With a user-friendly
arrangement of the operating elements and a sensitive, robust control dial, up to 69 special
locomotive functions can be conveniently switched.
• Graphic color display: A display must provide all the necessary information in an
easy-to-read manner. With the graphic color display of the PIKO SmartController, all
relevant
data can be read optimally even in difficult lighting conditions.
• Plug and Play: The logical structure of PIKO SmartControlan enables easy, timely
proper installation and use. This also arises from the use of several hand controllers
untroubled fun from the very first moment!
• WLAN hand controller: The updateable WLAN hand controller automatically connects to the
control center after switching on and thus offers wireless handling with a large range. •
Several locomotives can be controlled individually at the same time: It's fun to run several locomotives
at the same time. PIKO SmartControl has a max. output current of 2 A so that the control center
does not run out of breath right away. If the system grows, there is the option of adding
suitable PIKO boosters.
• Full DCC compatibility with RailCom and RailCom Plus®: Open communication is important
to us! That is why PIKO SmartControlan has full DCC compatibility for all locomotive
addresses with all locomotive functions. Suitable vehicles register automatically
via RailCom Plus® and can be operated immediately!
⚫ Extensive locomotive database: Many locomotive data sets can be saved.
• Switch accessories: Turnouts and signals can of course also be operated with PIKO
SmartControl. There are hardly any limits here, since the accessories (including multiple
terms) can be switched in an address space from 1 to 2048.
• Routes (only with #55821): An initial automation of the driving operation is also possible
with PIKO SmartControlar! The accessories can be grouped in up to 18 logical units
with 9 switching commands each and pause times can also be added to the sequences.
• Main track and programming track output: These are set up separately, so that programming
processes are also possible independently of the model railway layout, for
example at a desk, whereby the popular main track programming (POM) can also be used during
train operation.
• Short-circuit protection: Operational safety is important! And should something happen
anyway, the PIKO SmartControlan digital center has a short-circuit protection.
Have fun with the new PIKO SmartControlar digital center!
SOLD
Edited by Stoby
