ofey Posted September 12, 2017 Posted September 12, 2017 Hi, Recently I was using some line drawing to try to create a 3D model with openSCAD. The drawing has some dimensions marked on it but many are not. So I created this simply and crude tool which will allow measurements to be taken on a line drawing. Basically you upload an image, usually a line drawing. Mark a known distance and input the value of that distance. Then you can mark any other distance on the image and find its dimension. A demo is running on github's gh-pages. Check it out, https://shanegibney.github.io/Scale-Canvas-Upload-Image-Dimensions/ If you're interested the full code is here, https://github.com/shanegibney/Scale-Canvas-Upload-Image-Dimensions Thanks, Quote
