Signal
Signal's Achievements
Rookie
Rookie (2/14)
  • First Post
  • Conversation Starter
  • Week One Done
  • One Month Later
  • One Year In
Recent Badges
10
Reputation
  1. Hi Wiggy Thanks for reply and sorry for delay in responding. I've tried all combinations at this stage and am nearly suspect of Lenz equipment at this stage. I will take you up on your offer to test chip thanks but really don't know how to set about it. Guess email would be a start? I live in Wicklow and I guess you are in UK. Larry
  2. Hi Wiggy Did as you suggested ... put supplied chip back in ... lights come on and loco runs as 0000. I'm trying to get all the functions working but function 0 would be a start. I have another working with a EZ command chip and it runs ok but it only has a one function as far as i know and that the running direction lights. I've read the Lenz manual but I'll be the first to put my hands up and say i don't understand all of it. Again thanks for your time on this. Larry
  3. Hi Enniscorthyman This DCC is all new to me and I would prefer to try all other available options / suggestions first. I live in Greystones
  4. Hi Chip inserted correctly but thanks for response. Signal
  5. Hi Rob Thank you for your response. I've looked and looked again but I can't locate the switches you mention. Are the visable as the loco is viewed inverted? Regards Signal
  6. Hi Wiggy Thank you for your welcome and your suggestion. I've now programmed the loco to 22 as you suggested and still no functions. I've also checked the chip is fully 'home' Not looking too good at moment? Regards Larry
  7. Hi Irishthump, Thank you for your welcome and the link. I'll have a look at this link and hopefully see some suggestion. regards Signal
  8. Hi All I'm new to this forum so please forgive me if this question is not posted in the right place. I've recently purchased a Digital Lenz Set 90, a Murphy Model Class 201 and a MM Chip for same. The Loco seems to run fine but i can't seem to activate any of the Functions even function 0. As a result I suspected the chip to be faulty and returned it for testing but instead received a replacement chip. This replacement chip works the same as original chip ie no functions work. The two chips can hardly be faulty? Can anyone enlighten me on this issue please. regards Signal
