Cravens.
1 answer to this question
If by green ones you mean the Dublin based heritage set, which is mostly green, then the answer is yes. They ran together until the heritage set was withdrawn in 2010. There was also two green cravens in a temporary livery for a while (1529 & 1539) Then there is the Whitehead based MK2 set and the cravens have not run with those, while the couplers and brakes are compatible the the gangways are not.
