wiggy Posted August 1, 2012 Posted August 1, 2012 Any one had any problems with the Lenz 152 Xpressnet interface. Symptoms are that when you remove the hand controller from the bace station and plug into the 152 interface all I get on the display is 'HL-100' Does not matter what button I press it just stays at 'LH-100' All new interfaces and cables. The units power up (3 in all) tried using just one unit (152 that is) and only using one hand controller. I do know that if you use more that one controller you have to set each one an address. Have tried changing the address but still no joy. Tried another cable still the same. Reset to factory defaults, no joy. Any one any ideas.??????? Thanks, Wiggy. Quote
wiggy
Thanks,
Wiggy.
0 answers to this question
