kevrail Posted December 23, 2012 Posted December 23, 2012 here are a few photos of my Tesco store as requested by Grange Castle. This is a Hornby kit plastic which requires no painting. It is advertised as a cafe and has transfers to be added of required. I have just added TESCO transfers and have lit inside with LED strip.
Kirley Posted December 23, 2012 Posted December 23, 2012 Is there any particular supplier you would recommend for your LED strips & bulbs?
kevrail Posted December 23, 2012 Author Posted December 23, 2012 Is there any particular supplier you would recommend for your LED strips & bulbs? Kirley For my led strips I use this guy on ebay http://www.ebay.co.uk/itm/SMD-Strip-300mm-length-12v-YELLOW-3-for-2-available-/150779862421?pt=UK_Trains_Railway_Models&hash=item231b2e1d95 They are led strips which can be cut and soldered and you can have different colours and using them in Metcalfe kits is good from the point of view that they do not disappate heat. He also is good if you need any questions answered. some of his other kits seem quite good also. For the street lamps I bought from ebay in Hong kong but not really impressed as they are wheat grain bulbs and tend to give off too much heat. I have also used Pre Wired 5mm Clear LEDs with White Light for DC12V - DC16V which also come in 3mm of ebay and these are not too bad. An example of thses are the COKE Machine on the platform which has a 5mm led inside it. If at all where possible I recommend the use of LEDs as opposed to Wheat Grain Bulbs as they are safer. http://www.ebay.co.uk/sch/Trains-Railway-Models-/479/i.html?item=400317779751&ssPageName=STRK%3AMEWNX%3AIT&_dmd=2&_ssn=wehonest_cn
Kirley Posted December 29, 2012 Posted December 29, 2012 KirleyFor my led strips I use this guy on ebay http://www.ebay.co.uk/itm/SMD-Strip-300mm-length-12v-YELLOW-3-for-2-available-/150779862421?pt=UK_Trains_Railway_Models&hash=item231b2e1d95 They are led strips which can be cut and soldered and you can have different colours and using them in Metcalfe kits is good from the point of view that they do not disappate heat. He also is good if you need any questions answered. some of his other kits seem quite good also. For the street lamps I bought from ebay in Hong kong but not really impressed as they are wheat grain bulbs and tend to give off too much heat. I have also used Pre Wired 5mm Clear LEDs with White Light for DC12V - DC16V which also come in 3mm of ebay and these are not too bad. An example of thses are the COKE Machine on the platform which has a 5mm led inside it. If at all where possible I recommend the use of LEDs as opposed to Wheat Grain Bulbs as they are safer. http://www.ebay.co.uk/sch/Trains-Railway-Models-/479/i.html?item=400317779751&ssPageName=STRK%3AMEWNX%3AIT&_dmd=2&_ssn=wehonest_cn Thanks Kevin
Grange Castle Posted January 1, 2013 Posted January 1, 2013 Thanks for the pics Kev, got my kit delivered today gonna start on it soon, hope it turns out well
