Ballykeen Road
Thanks Noel, the plan for the goods shed behind the station was for a disused shed with some wagons rusting away in the siding. The other shed on the right is newer (1970s - 1980s) and to be used for freight of some description. Ive drawn the siding at the bottom breaking off from the loop it does leave the area where the loop joins the main less congested and may be better for accessing the sidings.
Jonathan, yes I will have an access point in the middle as before to reach the area at the back. I'm not sure how to set the board up on this with a hole in the center yet :)
