bhoulihan Posted December 27, 2017 Posted December 27, 2017 I have a dcc layout but I have a few dc locos and rolling stock is there a way of running dc locos on the layout on it I have a hornby R8012 HM 2000 controller can just swap controller Quote
Noel Posted December 27, 2017 Posted December 27, 2017 Yes one loco at a time, if you completely disconnect the DCC controller beforehand. Obviously because all of the track will probably be live you will only be able to have one DC enabled loco on the layout, and control one loco at a time. If you have any DCC chipped locos on the layout at the same time they should not move, unless you had enabled DC/Analog mode in CV29 (i.e. you won't have to remove them from the layout). Quote
