fitzguttentite Posted October 8, 2012 Posted October 8, 2012 Hi to all im like a @@@@@@@@ antichrist here i just dont know whats going on i have 3 baby gm,s 2 bachmann steam locos one american diesel { ALL CHIPPED } whatever i done this morning i have lost all { nothing running now at all } i use the hornby dcc controller the 3 baby gm.s are fitted with chips from marks the bachmann american diesel is fitted with a bachmann one of the steam locos is also fitted with a bachmann and the other with a hornby decoder when i go to programme the dcc it flashes 8 times should only flash 7 { according to the manual } i know { hope } this is an easy fix as you guys will be well up on this subject just damm frustating i need to programme all the locos and LEAVE them on the track i suppose and stop lifting them off and putting them back WHAT AM I DOING WRONG any help as always much appreciated fitz
0 Robert Davies Posted October 8, 2012 Posted October 8, 2012 By the time I got to your state I'd be looking at doing a factory reset on the controller! Which btw on the Hornby Select = Press and hold the 'STOP' '<' '>' keys all together, it should then show 'CS', press 'select' the display should show '0', press 'select' again, the display should show '03' and that's it! btw this does NOT affect the locos!! Regards, -Rob -Rob
0 fitzguttentite Posted October 8, 2012 Author Posted October 8, 2012 Thanks Robert panic over { all sorted } i was really worried , thought i had juiced the lot everything running in order now many thanks fitz
fitzguttentite
Hi to all
fitz
3 answers to this question
