Kelvin White Posted November 26, 2020 Share Posted November 26, 2020 (edited) Does anybody produce 7mm NG 21mm track gauges for Kalgarren code 100 flat bottom rail. potentially I could try and make some, but if there is a product out there I can buy it would be easier. I’ve just acquired a Ragstone Models Clogher Valley 0-4-2T etched brass kit and some Roxey Models etched brass CV coach kits. I want to knock up some track and points - copper clad & solder. Edited November 26, 2020 by Kelvin White Spelling 1 Quote Link to comment Share on other sites More sharing options...
David Holman Posted November 26, 2020 Share Posted November 26, 2020 Had mine (a basic roller gauge) made by a friend at the Chatham club, but had it done for Code 83 fb rail, which Peco sell. Might be worth considering this route as CVR track was fairly lightweight and it's no more trouble to make than code 100. The Ragstone kit goes together nicely, likewise the coaches, even though the design must be over 30 years old now. Great to see someone else doing 7mms scale, 21mms gauge, so will look forward to seeing how things progress. Quote Link to comment Share on other sites More sharing options...
Kelvin White Posted November 26, 2020 Author Share Posted November 26, 2020 Thanks David, I’ve admired your layouts when we used to have exhibitions. I have some Kalgarren rail , it looks a lot better than the Peco girder rail. I may have to ask some lathe owning friends a favour. What BB dimension do you use and tightest radius you’ve achieved? thanks Quote Link to comment Share on other sites More sharing options...
David Holman Posted November 26, 2020 Share Posted November 26, 2020 Used Templot 'Irish EM' points plans at 3' radius. Actually 20.2mm, so blew them up to 21mm on the copier. The b2b on Fintonagh is 19mm, with not a lot of leeway before problems start. Make my own axles from 2mm brass wire as I use Kadees and didn't want the uncoupling magnets grabbing steel ones. The Branchlines bogie coaches are probably the main limit to minimum radius, but can go round tighter curves of the pivot points are moved in a bit. Quote Link to comment Share on other sites More sharing options...
