Everything posted by J-Mo Arts
Very glad to hear the news about Drumboe! This is as far as I got with the class 3 this morning: The body is nearly finished, there are a few small bits to add at the front, some touching up and some rivets to add to the buffer beam. I then need to design the chassis, work out its dimensions and extrude a big enough hole into the bottom of the body to fit the motor. Thanks!
Not at all, thanks for the interesting points! Just out of interest, does anybody know if the layouts in the Donegal Railway Museum are 00n3 or 5.5n3? I didn't think to ask the last time I was up there.
I did consider it yes, but I wanted to stick to 4mm scale so that eventually I can have a layout of all three gauges I model (009, 00 and now 00n3). I'm going to use spare 00 gauge parts for the loco though, with new axles for 12mm gauge as I couldn't find motors cheaply, nor wheels, and I thought it'd be a fun (if not mad) challenge trying to get it all together! I like that layout, it's very sweet! Ironically too, but 00n3 holds the volume advantage for me as a 5.5mm scale class 3 would not fit in my printer! Thanks!
Thanks both! Unfortunately I don't have space for a fiddle yard on my layout-my carriages are stabled in two sidings at my main station and my running locos in a two road shed. I will however run my track right up to the back scene and make it look like the line continues. Jhb- you make a good point about the name and I have been a bit torn about it. I think I may keep to Marlfield Road, perhaps omitting the Portaferry entirely as Marlfield Road (to me, anyway) would sound a bit more in keeping with the Southern side of my layout across the sea in England. Thanks again
I've started the project, which I will be logging on my thread. Thanks to everyone for their help and answers!
I started making a County Donegal class 3 for 00n3 gauge recently, and this is my progress so far. It'll be the first loco for which I will make a custom chassis. I've decided to use the Hornby motor from their generic 0-6-0 chassis as it is smaller than the 0-4-0 can motor, I have one spare and will hopefully fit inside the loco ! The 0-4-0 wheels are essentially the right size for the driving wheels so I plan to use them and design bogies for the leading and trailing wheels which I hope to make on a lathe along with the axles. I didn't want to buy wheels as they're so expensive and personally I'm happy to try it this way. I think I will choose the route of kit building for the rolling stock as the loco will barely fit in my 3d printer, let alone a bogie coach! Thanks for reading!
That's a nice W&L loco! I've decided that my first 00n3 adventure will be a class 3. I've chosen this as it's the easiest to make for me: I can rob a realistic-speed Hornby 0-4-0 for motor, pickups, wheels etc and turn some new axles for it on a lathe, make some trailing and leading wheels on the lathe and 3d print the chassis, dummy outside frames, body and probably some of the linkage/running gear. It'll also be a fun challenge, plus then I'll have a loco to pull any wagons and/or carriages I make from brass! Thanks
Thanks for the replies! I had a thought to start 00n3 with a 3d printed freelance loco body onto an English or German chassis (where TT still seems to be made) and then graduate on to kits and CDR models. I may even be able to make a class 1 or 2 relatively easily. Phoenix is also an excellent idea if I can find a bogie to suit that is more in my price range. I have sent Neville at N-Drive an email to ask about the status of the class 5; last September he said that he was sourcing components like motors and wheels. I thought about either TTn3 using 9mm track or 55n3 using 16.5mm track but as I have both 00 and 009 I'd really like to keep to 4mm scale (I have dreams of one unified layout someday!).
Hello everyone and my apologies if this is a well documented topic. I was wondering what the easiest way to get into 00n3 modelling of the CDR is. I know that the Backwoods kits are slowly being re-introduced by N-Drive (I have my eye on the class 5) and I know that Worsley Works makes the 4, 5, 5a locos and lots of stock, however I'm reluctant to buy those locos as they need motors and wheels etc, which can quickly get too expensive for me. The Backwoods kits had all their wheels, motor etc already included in the kit which draws me to them. I must say that I've never built a brass kit before, but I've built plastic and white metal (I'd start with a wagon or a coach before trying a loco). I'd be really grateful for any opinions/advice on this! Thanks
That's a very nice scene and not a poor effort at all!
I was considering having a small siding off the run-round loop (at the end furthest from the camera). At the IoWSR we are planning to make a goods feature there in due course and I believe the original station had some sidings there. I like this idea a lot, but as I already have a town at one end on my layout and it's around 5m long (16ft) I don't really want to clog up the layout with buildings etc... I could always add the Illusion that the line continues on past the station as would have happened at Wootton in the steam days... Thanks for the suggestions!
I've printed the amended engine off and she's being painted, I'll share a picture in due course. As for a running space - my layout is a WIP end-to-end run set in southern England ca.1939/40. I have one station planned and half built but at the other end I am planning to have a halt which will double for the BCDR halt serving Portaferry. I will take Wootton (as preserved) on the Isle of Wight as inspiration for this: A simple platform, headshunt and run round loop. The buildings will be painted in as passable colours as possible for both the SR and BCDR as from what I've seen they're relatively close, and I'll leave off any insignia or company names. I may have a level crossing over the headshunt for some visual interest. As for the name, I was thinking 'Portaferry Marlfield Road', 'Abbacy Road' or 'Portaferry Mountain Road'; I like the idea that the station is a short distance from the town itself. Any comments or advice on this are very welcome! Thanks for reading and stay safe
Hi Colm, I believe I may be the 'modeller' referred to earlier in this thread as I'm developing a strong interest in the BCDR and have made such inquiries! I like the Lanky 2-4-2 conversion, I myself am making a 'freelance' BCDR 0-4-2 with my 3d printer, which is on my workbench thread should you wish to have a look. I'll be following this thread with great interest. Your work is really inspiring, thanks for sharing it!
Thanks to everyone for the help. I haven't yet managed to print off my new body (sidetracked with 6th form and narrow gauge, so I thought I'd upload a picture of the CAD drawing: This is the 6-wheeled coach that I mentioned, not my design but I'm happy enough using it for now. I am thinking about the new pre-grouping coaches in NBR livery as they're quite attractive, however I would probably repaint them anyway to fit with any printed/kit coaches I paint. Thanks for reading!
@jhb171achill, thanks a lot for the information! I don't think I'll be able to afford, or indeed have the capacity for, such a large fleet of coaches, but one or two would be nice and the shared livery with the LMS is useful for finding paints. I note your point about locomotives, I found a few drawings in the Manchester science museum which I may use to make a nice tender engine. Many thanks again!
Not much to report visually over the weekend. I've amended my design to include a bit more support on the coal rails and I've added valances. The traction tyres are now fitted and she runs much better, but needs a bit of weight over the trailing axle. I'll print of a 'Mk2' soon, get that painted up and ready to go. As for coaches/stock, would people recommend Ratio kits? I've found a brake 6 wheeler to 3d print from Thingiverse and I'll do that soon too, by itself it may form part of a track gang train or something. I'm not particularly knowledgeable about the BCDR but from what I've read they used almost exclusively 6 wheeled carriages, plus they ran a goods service from Newtownards to Portaferry by road so plenty of wagons will be needed too! Thanks
Just come across this thread and some really excellent work! That tank engine is charming!
I've started painting her, but not finished yet. Also, the 14xx I bought didn't come with traction tyres, hence the middle wheel sitting oddly. I will buy some of these at some point soon. I will probably print off a better body at some point too as the coal rails failed to print on this one and a few other minor things, but I'm happy enough with this so far.
Does anyone know which paint to use for the dark green livery? I'm thinking a Phoenix GNR loco green with BR mixed traffic lining transfers.
How's this? Handrail to go on later. Thanks for this. What I mean is extruding the tanks upwards while also moving the details on them upwards too. Instead of them staying where they are and the tank top moving around them (see above). If I go back in the history and change the height, the cab goes funny and holes appear... I'll give your suggestion a go tomorrow.
So the 0-4-2 that I made this afternoon didn't quite go to plan: There's a lot wrong with it. The tanks aren't tall enough, the lip on the bunker is too big, the list goes on. I can't get the tank taller while keeping the lip and top details at the right height, if anyone knows how to do this in Fusion360 please do let me know! As it and the 14xx chassis that it fits are far too big to be the intended prototype I think it'll become a fictional class of locomotives for operating my fictional Newtownards to Portaferry branch. When this line was built around 1898-1904 the CME realised that a class of modern tank locomotives needed to be built to operate passenger and goods trains along the line under the strict regulations of the Light Railways Act of 1896, and so a larger sister loco to the older 0-4-2Ts from Sharp, Stewart and Co found its way to the BCDR. Making the branch operate as a light railway was economical for the BCDR and apart from the construction of the locomotives there was no huge cost to opening the line. The locomotives had a light axle load, and the trains were usually relatively short. Something like that, anyway...
A start on the 4-4-2... It might not be 100% accurate but I'm liking it so far... One thing I've noticed is the Belpaire firebox should be a lot more rounded on the sides, something I will have to amend. A 14xx is arriving soon to donate a chassis to the B&CDR, I'll also take measurements from the outline of that to make the 0-4-2.
Hello everyone, I'm starting this thread to log my progress in making some B&CDR locomotives and stock. Right now I have plans to make the 4-4-2 and the 0-4-2 tank engines : I'll be drawing these up in CAD and 3D printing them. I have a fictional Newtownards to Portaferry branch line in mind, so although I'd really like to make the 4-4-2 I think that I should make a nice train of bashed Hornby/Triang clerestories behind a little 0-4-2 to start with. Thanks for reading!
- 372 replies
- 12
Thanks very much! That's really helpful. I might start a 'workbench' thread if I get anywhere with this...
Thanks everyone for such swift replies. I'll write an email to the UTM and the Manchester science museum tomorrow and see if they can help me. That's a very fine model, and thanks for the kind offer, but think I'd like to have a go at the smaller 4-4-2T first.
