A4mallard
Everything posted by A4mallard
A4 Mallard's new layout - Progress so far...
A4mallard replied to Warbonnet's topic in British Outline Modelling
Fran, I installed that bridge on the layout this afternoon. your UP Gas Turbine had no problems, just eased it through, with the help of a hammer and some WD40 -
It's based loosely on a bridge in Killenard, portarlington. -
it's mounting card, it's the board the used for picture framing. metcalfe paving slabs for the corner stones and edging. the stone effect is done with fine ballast. -
Uh oh -
I have it wired on each level and all the storage tracks are wired individually but all the rail is soldered on the joints. -
i wish i could have purchased it all in one go -
It's taking shape Anthony, Only the top level will have scenery, I don't fancy ballasting 2000 plus ft of track..... -
I use wet wipe hand cleaners and just keep wiping it down. any new engines wipe the wheels down before you run them (particularly Helgan)
Heirflick, have faith -
kirley, very impressive, great shed, lovely woodwork. I had huge problems in the beginning of my layout with gradients, at one stage it looked like I would have to take down at least 2 levels. the problem for me turned out to be the peco track, brand new out of the box, there seemed to be an oil on the rail. I was having problems running trains with 20 wagons(box vans). now i can run 85 plus, took a bit of cleaning with the track but i got there in the end. regards bren
kirley, you hit the nail on the head, for me, it's all about the 'running of trains'. thanks for the comments bren -
having trouble resizing images -
kirley, i'll take a few pictures and get fran to put them up, I can't seem to get them to load. regards bren -
The idea behind the multi levels was to have 3 levels of storage and the top 2 levels for scenery. It means I can run 8 trains on each track, and I can stand in the scenery section and watch them go by. Makes me feel like a trainspotter. -
kirley, since the hobo ride was taken i've put in 2 and a half levels above the starting point. i'll try and do another one from the bottom right to the top, however it could be quite boring at 30 mins. bren -
Heirflick, this is the censored message " call me when your ready to start" bren -
boskoney I airbrush after I ballast it tidys everything up, I use 3 different colours, light tan, tan and a red brick red. bren -
Boskonay, I use diluted glue in a large syringe with a needle. I apply the glue between sleepers one at a time then drop the ballast into place, then blow away the surplus. I do approx 6 inches of double track at a time....... it's up there with watching paint dry. This way it dries in about 4 hours and it's not as messy as the traditional way. -
Thanks Fran, Thanks for all your remarks, very much appreciated. Fran should be down at the weekend so ill get him to post some videos. regards bren
