Hi Lads, I am having a problem with Seep points I am trying to install, to operate a set of Peco large radius points. I am using a Gaugemaster DCC33 point decoder with CDU. I am trying to operate two PM1 Seep points. I am operating a DCC Gaugemaster Prodigy Advance 2. Everything is wired up as it should be. The problem is, the points are not getting enough power from the CDU in the point decoder. I am using heavy enough wire from the decoder to the points as advised. They are about 1ft,and 10 ins, long. Is there a way I can connect another CDU, or would that blow the whole thing to pieces?. The bar is only moving about one eight of a inch or less either way.
controller
Thanks,
Controller.
4 answers to this question
