New layout for beginner
4 answers to this question
You need the screw to go into the concrete about 40mm and add the thickness of the timber to it. Use 5mm dia screw with a red wall plug, the hole size in the concrete is 5.5mm. The screw is over size for this plug but it will give a very strong anchor to the wall. So if your timber is 30mm thick you will need 5 x 70 screws.
This method is great for load bearing and won't fail.
