IrishModelRail Posted November 18, 2013 Posted November 18, 2013 When 'Relay Train' is listed on the weekly circular, is it referring other LWR or what? Thanks, Seán.
0 ttc0169 Posted November 19, 2013 Posted November 19, 2013 When 'Relay Train' is listed on the weekly circular, is it referring other LWR or what? Thanks, Seán.[/quote The relay train consists of approximately four wagons of concrete sleepers,the Donelli relaying gantries and the spacer wagon while the LWR train has only wagons loaded with long welded rails or 'strings'as they are commonly known.
0 IrishModelRail Posted November 19, 2013 Author Posted November 19, 2013 When 'Relay Train' is listed on the weekly circular' date=' is it referring other LWR or what? Thanks, Seán.[/quote The relay train consists of approximately four wagons of concrete sleepers,the Donelli relaying gantries and the spacer wagon while the LWR train has only wagons loaded with long welded rails or 'strings'as they are commonly known.[/quote'] Ah I see, thanks for that:) I never knew the difference:D
0 irishthump Posted November 19, 2013 Posted November 19, 2013 Can I ask what the "weekly circular" is?
0 IrishModelRail Posted November 19, 2013 Author Posted November 19, 2013 Can I ask what the "weekly circular" is? Sure:) It's the information sheet that all IÉ employees get at the start of every week that has the times of all special movements such as railcar transfers, PWD trains, track machines, engineering works etc. To get a copy is impossible unless you know an IÉ employee...
IrishModelRail
Thanks,
Seán.
4 answers to this question
