Continuity Buzzer
Hi I am just about to solder dropper to the track and would like to know how does a continuity buzzer work. What do I connect the crocodile clips to? is it the track that I am soldering and the solder wire. Thanks for your help.
2 answers to this question
One clip to the track, the other to the far end of the wire.
How the buzzer works- the buzzer itself is a battery and a sounder. There's no sound because the circuit is open, at the croc clips. Close the circuit- touch the clips together- and the buzzer sounds. Open it again, and it goes off. Now you want to check if your solder joint is good, so connect one clip to the track- it's still open circuit, so no sound. Touch the other to the (bare) far end of the wire. If the joint is good (and the wire isn't broken) the circuit is closed and you get a noise. If you don't, the joint is bad, or the wire is bad, or the clip on the track has pinged off while you weren't looking.
Thanks Maitland for your help. That explains things. I thought that you connect the crops clips to the track and if you made a wrong connection the buzzer would sound. Thanks again.
