Goods Shed Clearance
GNRi1959
Is there any published dimensions of goods shed clearance at opening such as this at Omagh. The opening is actually to the right of shot, the other one, facing camera, was not an engine access. I'm sure its all standard but don't want to guess. Need height and width for single line openings.
3 answers to this question
at the end of this document is the modern 5'3" IE structure gauge http://www.irishrail.ie/media/ie_2015_network_statement_m.pdf
however since you are modelling in 00 gauge ( I presume ). This might be also relevant , when companied with the IE structure gauge
http://www.elginmodelrailwayclub.co.uk/2010/articles/advice/standard-railway-modelling-dimmensions.html ( bearing mind that Irish stock was wider )
regards
Edited by Junctionmad
Answer this question...
