Irishrailwayman Posted January 22, 2018 Posted January 22, 2018 Mr Soundguy supplies a wide range of UK outline sound projects while also specialising in Irish prototypes. A recent soundchip acquired from him for the new Dapol streamlined GWR Railcar produces some impressive results. See attached video kindly prepared by Enniscorthyman: 1
jhb171achill Posted January 23, 2018 Posted January 23, 2018 (edited) That would do, then, for models of GNR / UTA / NIR and CIE railcars of AEC origin... from that clip and from memory, it sounds sufficiently like the real thing, though all the horn-based squawks and squeaks don't sound realistic. The AECs had a quite distinctive two tone warning device. Sometimes the higher note was first, sometimes second. As a child it took me a while to work out why, until I saw how the driver operated it. There was a control lever which made one sound if pushed towards the driver, and the other if pushed away. If you sat in the first class section at the front of the railcar, you could see through into the cab and watch what the driver was doing..... Edited January 23, 2018 by jhb171achill 1
