Peco point motor wiring.
I am planning some changes to the layout and need advice regarding powering Peco point motors. Two crossovers are planned which will require two points to be operated simultaenusly. I am planning to use Capicator  discharge unit and a power source will be required. I was also hoping to use solderless female connectors to hook up the point motors if podssible  to avoid soldering in the vicinity of my foam baseboard. What size wire should be used? What output should the transformer have and what size female connectors  will work with Peco point motors? Any advise greatly appreciated.
Edited by patrick
3 answers to this question
Hi Patrick, I'm using Peco point motors and have wired up a couple to change simultaneously. Like you, I'm using a CDU to aid driving power to the motors - the Gaugemaster one. All droppers and points have 16/0.2mm wire used with no problems. For a power source for the point motors I am using an old 16v transformer from a Scalextric set or similar and again serves its purpose well.
The only thing I can't help you with is the female connectors as I've gone with the soldering approach. As an alternative to those connectors could you solder short wires to the motors to dangle away from your foam baseboard and then meet that with another wire and solder together at that point. Using the heat shrink wraps would then protect those joins.
Paul
Thanks Paul. I obtained a few wiring harness for peco point motors from hattons and thought I would make up my own to simplify wiring (I hate soldering). I guess I'd be better off biting the bullet and solder wires to the motors before installing them.
