KMCE Posted September 10, 2020 Posted September 10, 2020 Anyone know where to get a 4mm scale fitting for the steam pipe connection to the smokebox as per the image below. It is basically a cast elbow connecting the pipe from the cab to the smoke box. Difficult to do with brass pipe as it kinks when bending to such a tight bend. Thanks in advance. Ken
0 murrayec Posted September 10, 2020 Posted September 10, 2020 Hi ken Hard parts to come by! Best way to make them is with electrical copper wire and a few washers soldered on after one cuts the bend out, brass can work but would have to be annealed first- heat up to dull red and leave it to air cool. Eoin
0 KMCE Posted September 10, 2020 Author Posted September 10, 2020 16 minutes ago, murrayec said: electrical copper wire and a few washers Thanks Eoin, that method would work & could be done quite quickly. May redo the connection on the 458 as it looks a bit poor. Ken
KMCE
Thanks in advance.
Ken
2 answers to this question
