Louth
Everything posted by Louth
  1. Thanks for that article Branchline121. Currently there are 3 Enterprise sets along with spare coaches. A 200 metre FLIRT (or similar) would comprise about 10 carriages with a capacity of about 400+ passengers, similar to the current Enterprise sets. So 8 new sets should facilitate the proposed hourly service. The two big questions are whether the new units will be in service for the 2028 European Soccer Championships and whether a journey time of under 2 hours could be achieved once the DART is extended to Drogheda. I assume the planners in IR, NIR/Translink, the NTA, Dept of Transport, etc., are discussing these issues in the context of DART+ and the Strategic All-Island Rail Review. Hopefully some rational proposals will emerge later in the year.
  2. If you need any measurements of the Dunleer station Patrick, let me know. Access to trackside is a bit of a problem though. The car park side is no problem. Kevin
  3. Thanks again Patrick. The Wizard finials are perfect. Below are photos before cladding and after painting from the side. Kevin
  4. Thanks Patrick. I will take a few photos and put them up. I'll check out Shapeways and would very much appreciate the link to the white metal finials. Kevin
  5. Dunleer is an great prototype and your model looks great (the island waiting room in Drogheda is somewhat similar to the now demolished one in Dunleer). I recently completed a GNRI platform shelter using Ratio signal box windows. The building had to be constructed slightly over-scale to get the proportions correct. Dimensions were based on the shelter in Gormanstown which is one of the few remaining on the system. I have almost completed a GNRI signal box, again using the Ratio windows, but am a bit stymied by how to do the gable-end finials. Help anyone??
  6. Enterprise journey times in 1970 were 2 hours and 15 minutes with stops at Dundalk and Portadown. What is at issue here is not the headline time which can vary depending on time of day and number of stops, but that the Dublin-Belfast service will be considerably slower once DART+ is implemented. It is also contrary to the aspiration of "higher speed" Intercity services.
  7. Most of the route could cater for a third track without further land acquisition, but yes there would still be a significant cost. Irish Rail and NIR are planning for an hourly Enterprise service with "higher speed" Intercity trains. This just cannot be achieved with the current DART+ proposal.
  8. At the same time, Irish Rail are extending the DART to Drogheda with a big increase in the number of commuter trains. The Enterprise already crawls in from Malahide and in the future will crawl from Drogheda. In 1947 when the Enterprise service started, it took 2 hours 15 min from Belfast to Dublin with steam locomotives. Journey times are the same today. Based on DART+ timetable estimates from Irish Rail, the Enterprise will in the future take well over 2 hours 30 minutes at peak times (and this is being optimistic). Another consequence of DART+ is a shuttle service between Howth and Howth Junction rather than direct services to Dublin. The solution is to increase the number of tracks from 2 to 3 or ideally 4 between Malahide and Connolly as was done on the Heuston-Hazelhatch portion of the Cork line. If you wish to make a submission to Irish Rail, send an email to DARTCoastalNorth@irishrail.ie by Friday 23 of June. Full details on www.dartplus.ie
  9. Johnson's Atlas and Gazetteer of the Railways of Ireland gives a wealth of information on historic lines and stations but unfortunately doesn't seem to distinguish between single and double tracks. However if you have great patience and eyesight, you can look at the historic maps on the Ordinance Survey Ireland website (osi.ie). These show which lines were single and which were double.
  10. DART+ will add more commuter traffic to the Dublin-Drogheda line. This will slow up services from Belfast and Dundalk which tend to crawl in from Malahide already. The only solution is to four-track the line from Malahide to Connolly (passing loops would be an interim solution) and to remodel Connolly itself. DART Underground would also make a big difference and allow services to run straight through to the Heuston and beyond. We will have to wait for the outcome of the Strategic Rail Review and DART+ consultation process to see what solutions are proposed.....but I wouldn't be holding my breath! We will probably get hydrogen powered trains instead.
  11. Louth
    Louth
  12. Best bet would be a Hunslet and a set of maroon/blue Mk 2b coaches. I can't guess the third but am waiting with much anticipation!
