Everything posted by Patrick Davey
Patrick Davey replied to Patrick Davey's topic in Irish Model Layouts
A few small structures on the workbench at the moment: stone arches for the culvert where the stream passes under the railway, and a small girder bridge for the beach road to pass over.- 755 replies
- 14
Simply sensational - jaw dropping stuff!!!
And..... the path up to the future church has been taking shape, complete with fine 'wrought iron' gates courtesy of the folks at Scale Model Scenery:- 755 replies
- 13
- 755 replies
- 10
- 755 replies
- 20
- 755 replies
- 12
I exhausted my stock of hanging basket liner so I got some more, but it’s a slightly darker shade of green - should actually help create more realistic varied ground colours. The remaining white areas will be covered in DAS clay for roads, the beach and the station forecourt area. Have also marked out the footprint of the church and built the girders for the overbridge, from mount card this time rather than my more typical plasticard.- 755 replies
- 12
Maybe because it's not a micro layout - makes sense now thanks Alan!!! -
All good questions but I have no notion!! Might be able to salvage a flat wagon out of it at least....... -
Have no idea - and even more of a mystery is the fact that only one of the two wagons was so affected!!!! -
But in better news….. I have started applying the hanging basket liner base for the landscape. It looks like a bit of a patchwork quilt just now because I’m using up the offcuts from previous projects, but all will be blended together with scatter material and foliage etc. -
FILE UNDER: HOWLERS Sometimes you just have to put your hands up and admit you made a complete mess of things.... Yesterday, I completed two of @leslie10646's fabulous new GNR wagons, and even if I do say so myself, I didn't do too badly as there was a decent even finish with the Halfords primer, and I took extra care to get the decals positioned properly before sealing everything with matt varnish. So far so good... These were intended for the sand traffic at Clogherhead so I put some of the actual sand into each wagon, thinking it would be a good idea to drop in some dilute PVA glue and let it set overnight...... Sorry Leslie......... -
Had a challenging week with family stuff there so there has been a slight pause in the progress on Clogherhead. But I managed to find a nice distraction: The two vans at the back are the two I received from John @Mayner and the others are @leslie10646's Provincial Wagons kits. All fine models!- 755 replies
- 10
Two amazing videos there - so much to see, all long gone. And as for the H&S on the Hunslet tour...... yikes!
Yip - impressive!!!
Work gets busy in a few weeks Derek so gotta try and make as much progress as possible -
Good start!! In case it's helpful, there are a number of freely available kits which provide detailed interiors for signal cabins, the levers might be particularly tricky to scratchbuild in OO. The Ratio plastic one is great: https://www.gaugemasterretail.com/ratio-553-signal-box-interior-kit.html?gclid=CjwKCAjwxaanBhBQEiwA84TVXPkQPw7X7vQkjlmE00M0qY4YaD8WMvwEe5dDt_mSIbojbL3fQOsLlxoCWeAQAvD_BwE Then there's a white metal one by Springside Models: https://www.ebay.co.uk/itm/385656762946?chn=ps&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&mkscid=101&itemid=385656762946&targetid=1405282543879&device=c&mktype=pla&googleloc=1007289&poi=&campaignid=17218284410&mkgroupid=142217514411&rlsatarget=pla-1405282543879&abcId=9300867&merchantid=6995734&gclid=CjwKCAjwxaanBhBQEiwA84TVXIwaxZPnZsMcBto3Plpb8ISyIaXEEUFd1_O1hIKxb7X9d-2dS93G5xoCeUEQAvD_BwE Enjoy the build!
Lovely scene Derek - thanks for sharing! -
Further progress - the bridge is the scenic break.... this may have been done a few times before but sure if it works, why not!- 755 replies
- 10
- 755 replies
- 14
After all the excitement of exhibiting Brookhall Mill at the Belfast show, work has resumed on the landscaping of Clogherhead, using 5mm foam board as well as some thin card. Overview: Looking along the beach area: Looking down into the station forecourt: There will be gates here, leading up to a church and cemetery: A small stream will run down from behind the cemetery, under the railway, and into the sea: Looking towards the overbridge: -
Wow Alan and Gordon - that looks superb!!!!
Nice acquisition at the Belfast show yesterday from the mighty man Chris Dyer! Thanks also to Dave Bracken and Alan for sorting out a slight running issue.- 755 replies
- 10
