Sean
Everything posted by Sean
video-1645342245.mp4 well holy moly! went deep down a rabbit hole with jmri tonight and this is the result, theres an EMD 645 sound also hard to show it off on such a short bit of track but its a start! sound is coming from a stage monitor with the bass cranked sitting just behind me. still feel like im only just barely scratching the surface with jmri, it has massive potential. ya theres weird conditionals tied up so that they were only working with the headlight and even then the front marker was tied up to the headlight with no apparent solution unless you reprogram. actually murph I did install rocrail tonight but i had no clue what was going on so i left it, I was looking for a way to hook up to multimaus etc using the Roco proprietary lan protocol so that the rocrail system would appear to other devices as if it was a z21 box. found a super interesting implementation of what i have in the video above but unfortunately it only works connected to a z21 station. it actually seems way better than the jmri implementation so if i could get the rocrail to be a z21 it would definitely prompt me to switch over to that platform in a heartbeat.
new year new layout 1990s container terminal and tmd
Sean replied to Sean's topic in Irish Model Layouts
not looking too bad after a sanding, plenty of low points though so ill be filling those in tonight. took the chance to fill any imperfections in the das and then just did a full skim over the entire yard area. used a different type of filler tonight which was a powder type as it was cheap and advertised as being ready to sand in an hour, and it was! ill probabaly using this stuff where possible from now on. Irish Locos, working lights, hard standing, irish bufferstops, lights reflecting off rails, ive died and gone to model train heaven. Happy to see a few different sub projects coming together in completion on the baseboard. video-1645255724.mp4 Finally i should add, i used a slightly different methodology for making the grooves alongside the rails, instead of a knife and ruler i took a plastic card ( expired leap card or license etc) and i cut it in half to give me a sharp edge, i was able to dig the card into the inner rib part of the rail and use this as my guide to slide the card along and run down the lenght of the rail fairly quickly, I did this whilst the clay was still rather soft and could hold the card at a decent angle to get the required width in the grooves on the first attempt. will mess with the backscene tomorrow, as i feel its the next logical step in construction as it will be harder to fit later with scenery in the way! -
Thanks Adrian, ive been watching your thread with keen interest too, little has happened this week as i have been sidetracked by all things DCC, constructing my own controller and chipping the fleet ,no sound. just cant justify the costs, the lighting has me delighted anyway. I do have some good ideas for sound however they are still in the incubation phase in my head and require more evaluation before i can say anything meaningful on that front. the filler is finally at a spot where im not afraid to sand it, gonna be a little tricky since its essentially laid onto a bed of sponge but we will persevere anyway. gonna need another coat in spots so the odd crack wont be game over as long as it all stays adhered. two backscenes have arrived, shockingly they are 10cm short of covering the whole backscene despite my measuring them in advance. since my backscene is quite short though i should be able to get by by covering up the transition with a building of some sort. the excess sky will be trimmed off and can be used as the sky above the building in question. I am considering using a large low relief station building which overall would become a sort of centrepiece of passenger operations on the layout. ive also got a signal box ive been messing about with it but i just think the space isnt there for that. will get back to a turntable soon also, i didnt like the old one so much after a little while so i have left it off the layout for now. ive since discovered some cooler designs also so will get back to one of these in due course. i have even considered buying an off the shelf one and just sucking up the costs however I dont actually have the space for any of these commercial designs anymore so thats a non goer. to be fair i think ive made use of every inch of the available board without making it overly cramped looking thanks to the open yard at the front. -
Diving into EncoderPro this software seems to be very simple and will allow me to modify all CV's and functions on a given decoder. apparently its also possible to blow sounds but im not gonna get into that. with this in mind it has been possible to find a simple solution to the lighting issue. what ill do is very simple, i will analyse the function map of the A class chip and then place it into the 121 and go through the functions until i see the lights i am after, I will then note down which functions and their associated aux control the marker lights, then ill do another function analysis of 130's chip and replace the 2 marker functions with the ones from the irm decoder. with this software the manual states that the ui is modelled after lokprogrammer and by the looks of things it has more programming features than i would ever need. any parameters i mentioned so far seem to be moddable. I will add Forward and reverse rows for F1 and F2 with the correct Aux's labelled and that should sort things out on the lighting front. so as we see F0 has some weird conditions and F1 and 2 are blank,
And didnt i just remember that the 141 decoder is already coming in the post tomorrow, i guess that puts dodgy reblows at the top of ones priority list!
Well what can i say first impressions here actually have me super impressed, not knowing what was what within the software a quick youtube on how to get started got me to the roster screen and once i had a train added everything else became super self explanitory and really just worked. I can literally just pick a loco from the spreadsheet and hit throttle and there you go full control onscreen. the withrottle worked a treat too and now i can control 2 locos from the comfort of my couch/phone really liking how the locos will move off and coast to a stop over a period instead of just instant power. theres also an emergency stop button just incase that stops the train dead. the shunt/brake mode is also a fantastic thing to have although it seems to be set a lot stronger on the A class decoder. perhaps we will have to look into changing this somewhere within the decoder pro software. if i wanted to just leave it here with the software and be happy i could but there seems to be a whole plethora of stuff under the hood so im definitely going to tinker a bit more. I am liking the idea of using automating to shuttle in and out the push pull set, leaving the operator free to shunt the yard below or refuel locos etc. 2 minor issues have cropped up for me, firstly both decoders have been set up with address 3, so as of yet i havent been able to drive both locos independantly, I think its set on the decoder itself since changing it in the software seems to have no effect. however i need to investiate that more. Secondly I am finding the marker lights to be a little wonky on the 121 decoder, at first i thought they could not be set to work independently of the headlight at all, however, i then got the tail set turning on and off, but for the life of me cannot get the front marker to work independently to the headlight, its either all or nothing, is it like that because this is how it was prototypically or is it just a small incorrection on my chip? out of curiosity i put the A class chip into the 121 and was able to get all the markers working independently. theres no front marker on the 141 class so im thinking of the possibility of fitting the 121 chip into that and hopefully i can control the front headlamp and back marker, then ill get a second A class chip into 121 and there will be fully working lights on the whole fleet. is there a possibility of bringing the function 3 shunting light over to 121. did the real 121 have this light? ideally though i would like full control over the parameters on the chip and theres talk of that being possible, along with .esu reblowing without the use of a lokprogrammer using decoder pro so this will definitely have to be explored soon. but the address issue comes first. I would wager that if you know what a driver is and how to install it, then you would have no problem getting up and running with this. I really was surprised how plug and play it all is once i got past all the technical jargon/ That sounds very much so along the same lines as jmri alright, dcc++ was the base station i used and its very much plug and play, jmri itself supports connecting to a staggering amount of different base stations but not really sure how any of it works outside of dcc+ Was looking at that as it was showing up as a lokprogrammer alternative, I dont think things could get any more low cost than this arduino solution. if you are prepared to wait for china postage time you could be up and running with a base station for in and around 10 euro or less. for larger layouts requiring a higher amperage the cost really does not become to much higher either but a different motor solution needs to be used.
Starting this thread to document my first jump down the DCC rabbit hole, as always im on a budget so going DIY where possible, will be able to give a nice overview of just how easy or difficult it is these days and will also touch on costs and if its really worth it. so heres the starting point. basic old scrap computer running java runtime environment, this tiny net book was perfect, to small to be practically usable and old enough to be worthless without being completley useless spec wise. plenty of power to run trains but little else and easy to carry around. any old computer running windows would suffice really(I dont use windows but that doesnt matter here), you can skip the computer part and add networking directly to your base station which i was going to do however i cannot locate my network card, the laptop opens up much more possibility also so ill stick with it till i find the arduino networking card Arduino Uno or Mega, Mega is needed for a standalone network base station. generic old laptop power supply. Engine driver Wifi throttle for android. Official arduino motor shield, to assume maximum compatibility with the project as it is now. Official IRM and MM decoders. considering the cost of an ESU unit on its own i did not mind paying the extra few euros to have pre programmed ones starting off with to make the process that little bit easier, in time im also going to try and reprogram these decoders without programmers, thats a whole other can of worms though and im aiming for the basics just now! cheaper decoders will be explored in time. DIY decoders on locos seems next to impossible if not very difficult. so i dont mind justifying the costs for now, DIY accessory decoders seem alot handier however and we can take a look at these. as for costs so far, pleasantly surprising, i already had everything on hand except the decoders and the shield, went for an official shield to ensure maximum compatibility and this was 17 euro however i seen some clones on an irish site around the ten euro mark and china would be cheaper again, the Mega im using cost me less than ten euros a few years ago from china or ebay and i know clone unos are about a fiver..... so what does this mean? well basically for those with a spare computer that can run an older version of windows half reasonably, it would be possible to assemble a DCC base station for around 10-15 euro. how easy it will be to set up and run remains to be seen, however given my initial tinkerings with the JMRI software and engine driver i am feeling quite positive that it will be. will update later when ive had a good go of the software. have the arduino flashed and talking to JMRI over serial just fine but thats just as far as i got before bed yesterday. got engine driver set up with a layout that i really like but did not connect it to JMRI yet, assumedly once i do that and chip some loco's i am good to go but that still remains to be seen!
have been wanting the shapeways n stuff for ages but the high costs for what you actually get have always put me off.... what do i want from 3d printing? well, the ability to purchase files of models and print out as many copies as i would like, just like we do with scalescenes stuff now. otherwise its no different to buying brass or resin kits, to me at least quality aside.
some really good advice here folks and i think the best take away is to err on the side of caution with things. sound seems nice and all but at those prices, i just might have to pass, i love the idea of realdrive but need to be able to justify those high costs, the audio engineer inside of my brain has been trying to come up with other ideas for adding sound to the layout which in reality may just be a little more practical (and much better sounding to boot) that same audio engineer would probably quickly become tired of the sound of trains through iphone speakers as robert has hinted at above.... I wonder what work could be done in this area to improve bass and fidelity of onboard speakers, phones have improved MASSIVELY in recent years and there may be a scope to bring some of that technology over to a locomotive. thats a topic for another thread however which merits further investigation on my part! the layout in mind is very simple with no more than 2 locos running at a time, but its a very slow moving depot so my biggest draw again is unlocking the full potential of the lights as i want to be able to fully light the layout over time also. DCC accessories dont really interest me and im happy to do points by hand for now, ill eventually electrify them but thats practically going to be years away. so with all this in mind, and no particular limits on time as i have an exceptionally(for me) smooth DC controller im probabaly going to order the arduino shield and one single soundless decoder and play around on a lenght of track to wet my feet and that way i will soon see if its for me or not. Will probabaly go with an official IRM of MM decoder to start with as they dont cost a whole lot more than the generic ESU ones and i know all the functions will be as they need to be to get started with.
Interesting food for thought Dave as its not usually you hear from someone who is more for DC my biggest annoyance with DC is how the lighting on the loco is controlled and i dont really want to turn those lights off either... @Murrayec due to budget constraints i really am leaning towards the DCC++ option, mainly because i have virtually everything there already except a motor shield and decoder so i can be tinkering. I build midi controllers driven by arduino boards so am also kind of interested in seeing just what it can do with a train. that being said you are probabaly right about the decoders, and i dont want to risk blowing up my lovely trains!!, so can at least justify getting those. are you saying the sound and non sound ESU chips the same at a hardware level and can be programmed with sounds later? control from a phone or tablet really appeals to me.
RIP RAWIE NUMBER 5 slightly nervy but enjoyable work, not bad going for a couple of hours. had to use fillers in a couple of spots as i was low on clay, so may need to leave a good few days before sanding it down etc. will have to see how it goes. pulled the molds off early because i dont want a perfect concrete edge i want it to be broken and distressed. Also cut out and glued down the loading platform, and also with this brings another change of plan, beet hoppers have always been on my list of wanted rolling stock, but with no real justification to get them due to lack of facilities on the layout. and since im rather partial to hopper type wagons in general, and magnesite are coming. I have decided that instead of a disused loose coupled loading dock that it can be an in use loading dock to cater for all types of mineral hoppers complete with period clapped out 10 or so year old JCB! watch this space.... -
lifted everything off the board again to do the usual "slab the whole yoke with polystyrene" treatment and to lay the underlay, hopefully the trackwork is a little more forgiving now! just about ready to fill this lot in with das and hope for the best! madly the styrene exactly matches the rail height with the underlay underneath! -
my biggest gripe is not being able to control the lighting and the lighting operating like a dimmer switch as the loco runs though slow operations Anybody using DCC++? looks right up my street.
hey guys, looking for some info on this topic and in general I have absolutely have no idea where to start as i have only ever had DC systems where can i find out about wiring? whats the best entry level controller to pick up and are there any available second hand? could an arduino be used to put together a controller in a DIY fashion? In regard to the decoders on the loco i have much the same questions. not sure what to look for, i think all my locos are 21 pin. what are the best entry level decoders that wont break the bank and is there any chance of finding them second hand? again can i DIY them? I would consider myself to be quite proficient at the DIY side of electronics so should be able to tackle somthing if such a project already exists. I understand sound to be quite pricey so can live without this for the moment but id like the option to be there so i can easily add sound in future. Locos to be chipped are MM203 MM130 MM143 and IRM007 ahhh so many questions Cheers.
with this talk of backscenes i cant help but think about a layout with no backscene, or one that is simply solid green! going to experiment with just that on my N layout. a green screen backscene would be very interesting indeed for photography purposes!
off to shapeways i go........
shied away from work on the layout over the week as a disastrous first operating session had been plagued with constant wagon derailments on points, particularly during reverse shunting, chalked it down to a mixture of hornby points combined with an extremelly unlevelled track bed. I had considered replacing all the points with peco(which i still may do for reliabilitys sake). Had another go friday and had a nice few hours of operation over the weekend , up until now i had not seen any need for DCC and sound chips and all that malarky, despite having a degree in audio production! but now i am seeing it as one of my most wanted features to add to the loco's and im thinking about other ways i could experiment with incorporating sounds into the layout. Perceptually its a bit weird seeing the trains going around without making any sounds, a bit like driving an electric vehicle for the first time! a full yard will be a rare sight. MM203 the odd one out on era. perhaps as they climb in value to approach the 2000 euro mark some kind soul will trade me for an immaculate toothpaste IR 071 which is still in a sealed box video-1644720336.mp4 video-1644720329.mp4 video-1644720323.mp4 We did manage to catch a few videos of train movements down the newly built street, once you cross the tracks the road will continue left and i might get to squeeze in something low relief stuck onto the backscene, in to the right is the train station car park where ill be able to display around half a dozen cars, as i add them to my collection. Cheers! -
Interestingly relevant I have been working on converting this IRM flat for push pull operation as a camera dolly to give the "drivers experience" in the bits that i shoot, of course its gonna have the same issues of cropping and ill need to pan it to avoid staring out into the abyss when the train is moving in certain directions, but it should be cool for building little video narratives of the movements. one thing ive been trying to do with all my latest layout pictures is to get the camera lens down to eye level and attempt to shoot as if im a little 1/76 person holding a big camcorder, im hoping practice now should pay off with really atmospheric shots once the layout develops a bit more. im noticing its a little tricky at times given the size of modern phones!
anything i post onto here is done using the phone and cropped to hell,possibly filtered have an old slr that i was gonna sell but have decided to hold onto it since getting back into fish and railways, i know i will only regret it, only like 8 megapixels but so much choice given it takes canon lenses.
got some myself last week they are super quality.
We catch a quick glimpse of 143 as she arrives in with the dublin service, 007 awaits signal to depart with a liner. -
I have one of these that i built myself using a 6w hornby van, the middle axle should slide in and out as the wagon goes around corners.. if thats a silverfox unit it should be the same chassis from my oggling of the photos, the couplers should also turn through corners
Will the ladder and lid be removable to allow to become the ballast wagons as well?
hopefully this, and that they will be modular just like the 40's with different options available over time. beet, containers, tankers etc. I feel like it might be coaches though.
+1 On Irishmail from me too, just took delivery of a beautiful 143 a very painless transaction.
