Sean
Everything posted by Sean
as im a bit of a glutton for punishment ive started to piece together another familliar face, thought i was done making trains for now but this small pile of parts kept sticking its tongue out at me so i said i had better make use of them. not gonna be aiming for a super detailed example again although there are some elements which I want to spend additional time on such as getting the curve into the front of the cab and rear correct. a even has a lit cab! i should be able to think up a little circuit to keep it lit for a few seconds after the train comes to a halt. van is looking really well although not too photogenic at the moment with my poor lighting, will update tomorrow when i finish that one off altogether. quite looking forward to getting the windows fixed in after paint. this is its good side and most likely the side ill use the details on. other side is not terrible but it was done first and details like the door just didnt come in as flush as i could get them on this side,overall im very pleased with this van though,only thing annoying me is that this van is sitting slightly higher than the coaches and therefore the orange stripe is sitting a little too high and i imagine the white one will too, i think its partly because of the small scale of those tri ang coaches though so may be okay next to some proper irish stock. overall im happy with my little DIY branch line rake.
containers arrived today, they arent an exact fit for the large hornby bed. but its close enough for my layout and they do set a nice scene alongside the coaches. managed to get the windows cut into the heating van and they arent looking all that bad after tidying, this unit should paint up nicely , i took the plastic screen off an old broken thermometer and this should make up the window glaze nicely when cut into small pieces..
so among my old bits was this other little gem it used to form part of a fairly big breakdown crane on a one of the old ho sets i had as a child. plenty of doors and 2 little vent details i can use later, time to get my blunt cutting tool out. roughly 5 minutes later it has been hacked into a load of old doors and panels. childhood ruined. was looking for ways to easily cut into this wagon so i heated up the exacto knife with my lighter and it went through like butter, once i had the door in i got a little more confident and cut in the first window! not perfectly but tidied up with the bit of card. mistakes were made on the other side too! thank goodness for fillers when i get back to this ill use the masking tape all the way around the wagon following the lines of the windows i cut, i dont need them to be perfectly square(although it would be a bonus ha) as long as i dont cut them too big to ruin the lines of the livery. the exacto knife is able to make shave out a surprisingly square looking cut out though.
Some great resources there lads should keep me reading for a while @jhb171achill the carriages im working on seem to be pretty common and available for next to nothing online, i do have a couple of larger steam sets and a graham farish set and a few other goodies im strongly considering parting with at the moment though. not too much to report today as im tied up with other committments however I have gotten a little start on the heat van. like most things hornby this clipped apart with ease, still undecided about how to add a window and door at this stage, im torn between finding a very cheap damaged coach to use as a donor and just trying my hand at cutting them in when i find my dremel in the shed again. fairly drastic step next. but im completley sanding down the wagon on all 4 sides on a block of wood to deface it. that is then repeated on a nicer bit of sandpaper as 120 grit will have it left feeling a bit rough. So now ive basically got a blank canvas for a new carriage! decided to give it a coat of high build primer to start to fill in the heavy sanding job and highlight any imperfections left behind . ive got to take some more measurements but interestingly it has left the doors of the old wagon behind and these dont seem like they are a million miles away from where they should be.Could be onto somthing with this.
thanks for the feedback, for years ive wanted to set up an irish layout but always found it to be a little too costly starting out so hopefully this thread can encourage others who are in the same boat, I will probabaly pull the finger out now and finally buy one of the big diesels soon enough. interesting enough set on the workbench today. I have owned this set of tri ang coaches for many years, they were given to me by my grandad but i was never able to properly run them on my modern track due to them having very primative wheelsets which i did not know how to change causing them to derail almost always on points. Well recently i discovered how to change these wheels . so i have been thinking it would be nice to refurbish this set into cie black and tan in order to run on my layout . it has a few things going for it. the open coach is not a million miles from one of the opens in the silver fox 1951 set so in theory they wouldnt look too out of place in that livery, i think the brake van would be technically incorrect but i could later run it with some mark 2's as a heating van if i wanted to. there are lines molded into the bodywork which can be used as a template for masking off for the multi colour paint job and even with my skills it should turn out half decent. when compared to my set of hornby composite coaches these seem to be made to a slightly smaller scale. they are a bit shorter and the roof height isnt exactly the same either. this makes the track look a tiny bit bigger but more importantly space is at a premium in my station area and the missing inch or 2 of wheelbase does help a lot with clearance issues in the runaround loop. this is generally the longest train that will ever run on the layout anyway. due to the wheel issues they seem to be very commonly available for around 5-10 pounds online so there are loads of them out there, it is also a bit of a pain to fit modern wheels but its actually very straight forward without buying any additional bushings etc. Another thing i noticed whilst browsing the silver fox library was that their 6 wheel heating van seems to sit on another common hornby chassis which i actually happen to have in my posession in the form of the milk van , it seems to have the same black bed details as the silver fox van as well as the couplings which pivot with the middle wheel turning, so this seems like an ideal oppertunity to try and create my own 6 wheeler! We will revisit this another day as the coaches have absorbed all of my modelling time today and ive only painted one side of them as im taking my time with them. im still deciding wether to just repaint this one or somehow try to cut in for the windows so ill sleep on it. and decide. masking was a piece of cake as i could just lay the tape down along the plastic lines of the carriage so it was easy to know they were straight. much to my amusement i was able to simply fold the masking tape back up and i was masked for orange. I couldnt find any obvious way to take these apart and the bogies are riveted on so this is why the roof and bogies are masked instead of removed. no pics of the actual paint job, and only one side of the coaches was completed today however I do think they are looking good on the layout need to go back and tidy up some of the lines when the paint dries, particularly between the orange and black as there was no fixing it with the paint wet, the black section was painted freehand as i could not think of any obvious way to mask up the windows, they had fallen in though so i was able to paint most of the frames without touching the glass with my brush all that much. i reckon these will look really decent tidied up with some more details added. really pleased with the results of what i have achieved on this thread so far in just a few short evenings i think i have drastically changed the look and feel of the layout i have planned with more of an idea of how to actually build the layout to the strenghts of my new rolling stock. Will keep this thread updated as i hone my skills and begin to improve on the wagons here so far. As a bonus, I have come accross and old HO chassis which i thought i had destroyed forever as a child today, then i came accross its motor and driveshaft and noticed the pickups are still in place, once i wire it all up i may have to see about treating her to a shapeways 121 shell. are there any other 121 shells available?
So the reason i had been keeping an eye on the wagon chassis size is because i am considering container traffic on my layout and have ordered some oo guage 20 foot containers as I think they should fit just nicely on a large hornby wagon chassis if my measurements are correct. Unable to wait I found some HO guage containers that i could print out and make up on card, unfortunately i am limited to grayscale printing on blue card so they dont look amazing but give me an idea what to expect when the plastic ones get here. much to my surprise these fit really well onto the smaller chassis with just a little overlap, if it was scaled down just a tiny bit it would fit onto this flat perfectly and look great.(and of course printed on proper card in colour) unfortunately the container is a bit too short for the larger chassis but according to my measurements the oo containers should make up the extra cm and fill the bed, I think it would also be possible to take a lot of the underside plastic off this chassis with an exacto knife so it looks more like a proper container skeleton as well so it will be interesting to see how these progress next week. they do look half good being pulled out of the yard in a rake though. the great thing about working with either of these wagon chassis is that hornby sell a 3 pack of them for 20 pounds on their website and there are a lot of used wagons on ebay etc which would suit for these types of conversions.
as mentioned on the other thread, ive been trying to increase the amount of cie stock ive got without spending too much money so ive been looking for ways to convert existing stock to cie without too much effort/expense. Ive picked out a range of stuff from my collection that I can see will easily convert into cie stock so im starting this thread to keep track of what I do, The majority of the stock I am working with is available cheaply in some form or other on the hornby railroad range in some guise or is available in abundance second hand. Surprisingly I think I have enough stock here to fill out the layout with the exception of a larger diesel engine which is one thing i reckon I will just buy when funds allow. Interestingly the cheap hornby wagons seem to all come built on one of two common chassis, this actually helps quite a lot as can be seen later in the thread. the teign valley wagon is a bit more detailed and seems to have its own individual chassis but aesthetically its the quite close to cie wagon photos so its in for this job. so these are the first few wagons that seem the simplest to turn into Irish stock. the van and 5 plank wagon I am just going to respray into grey, later on I will add cie decals but its not a job for today, the grey brake van can pretty much stay the same until decal day as its not a million miles from an irish van it may get some body mods in the future but its okay as is for now. I couldnt decide on a colour for the brown brake van so its staying brown for now. It is however being moved from the long Hornby wagon chassis to the short one. im not sure how accurate this will be from an Irish standpoint , but it will make shunting a bit more interesting on my layout and im not a huge fan of brake vans with the open platform on either end anyway. getting this stuff apart is all very straight forward with plastic clips located on the underside to get the bodys off on a few seconds. the entire wagon including chassis is being painted grey with details to be added back on afterwards on order to reflect on the colour of the cie wagon, the vans seemed to mostly keep black chassis so this will be left alone for now. once the van is off its chassis we can see its the very same as the other short chassis which I will be moving the brake van onto. I have a few more coal wagons built on this shorter chassis which would also be suited to conversion although in my opinion they do not look as good. for paint I have chosen the very versatile Dealz primer grey rattlecans, I think the colour should be okay, if not at least they can be primed to take the correct colour. as we wait for this to dry its time to tackle the brake van, in theory it should just clip onto one chassis from the other as they are sold new like that,but we will see. unfortunately not, but a little dab of model glue onto each corner sorted that out easily. as the glue dried and the rest of the stuff went back together i put some small details back onto the wagon so it doesnt just look like a primed wagon. now the imaginary hornby cie tank engine finally has some appropriate rolling stock to pull behind it, will surely look good when detailed with decals etc. New shortened brake is looking right at home behind the tanker train. I have one more item of freight stock to start building before i start to focus on passenger stock. the four wheel coaches I am intending on turning into some sort of heritage train in cie green. the cleaning car has long since had its cleaning mechanism removed and the blanked out windows will make it convert into a nice little brake coach, these all run on the long hornby chassis and are available for next to nothing all over ebay.
So as I havent painted a straight line by hand in over 100 years I decided to do the first paint job without any sanding or filling as i knew it would be an absolute horror show either way, and well i wasnt wrong so theres little need to share this example experimented with adding the third wheel, which the chassis could successfully take however once the footplate was installed back on it was locking up the new wheel so I will need to revisit this later with a dremel when it goes back in for another paint job after ive had some more practice with a brush however for now I am very happy with what I was able to pull together in just a few evenings with mostly scrap and a chassis to run it on. back on duty breaking up the incoming tanker train. waiting for passenger services to leave in order to move test freshly converted load around the network.
after a good session of trimming,gluing and filling its straight into service shunting the incoming tanker train before a slot becomes available in the paint shop, soon she will be sprayed up into her original cie livery.
In all my years of playing with model trains I have never built any of my own items of rolling stock, but as I am trying to add more CIE stuff to my collection(on a budget!) I thought it would be a great time to start. I havent modelled anything except for badly put together airfix kits when i was younger so I am modelling from a complete beginners perspective on this one! This body shell comes from a toy HO guage set I had years ago, has been knocking around in my model box for years as i had always thought about trying to turn it into a 121 "one day", however of course that day never came, in the past couple of weeks I have been looking at photos of a lot of old stock to see what i could repaint or remodel into cie vehicles and so the E class popped up. I had been comparing this to my Hornby class 06 but thought there was too many differences for me to be able to do a convicing conversion when i came accross this old bodyshell and noticed that it shared a lot of details with the E class, big square opening near the front with a round opening on top, and louvred doors running back along to the cab, I thought great ill mate the body to the cab of the class o6 and that will be an ok first conversion, I will use some artistic license to make it into an 0-4-0 loco and it will look great on my new layout. On closer inspection I decided that the cab on the HO Loco had a closer window arrangement and although it had no door i would either cut one in later with the dremel or just leave that detail out, however now that im feeling a little more confidecent i may end up using the sides from the 06 cab to detail more when im done. So after undressing 06 and hacking away at the bodyshell for around half an hour with a blunt instrument I was left with this, notice how I have also dug out a spare set of loco wheels from my spares box ;) the plastic card is just a random bit of plastic card i found in the house. now time to start trying to turn it back into a locomotive! So a little while later this is what i have ended up with. the back of the loco has been built back up with plastic card and now needs to be trimmed down to shape, the 06 footplate got its buffers removed and a spraying of black paint, the engine section has had its chimney filled in as well as the headlight hole on the front, I did sand the front flush to look more like the E class however the blob of filler has meant i need to do it again. finally starting to look like how its supposed to, the body will be able to slide forward a few mm on the footplate when i trim off the bottom of the plastic card which will improve the overall look, im really looking forward to getting the 2 body pieces mated together and looking nice so i can put a cover of black paint on.
