I am finally able to begin track laying on my DC layout and I need help wiring the track. I am using ideas developed by Ed Ravenscroft for using points (or turnouts as he calls them) to feed power to tracks and thus cutting down on the number of toggle switches needed to power/isolate blocks. Using a point to power/isolate a block when the power is originating on the common den of the point is easy. However sometimes I will be routing power 'backwards' through a point, that is originating in one of the divergent tracks past the frog. the picture and text I've attached shows what I'm aiming for.
Since my electrical skills are very limited I need help choosing components and with the wiring diagram. My vague plan so far is based on the wiring diagram to the right and to use Seep PM1 point motors to move the points. Then use the switch on the PM1 to signal to a gaugemaster GM500 latching relay to connect the 2 tracks at the common end of the turnout to the 2 tracks of either the divergent or mainline tracks past the frog. Would this work?
raymurph
Hello,
2 answers to this question
