JM Design new materials, finer detail and lower prices!
We have received our first production order from a new supplier and we are now able to sell our 3D printed wagons at a lower price point!
Our new supplier has the capability to print models in engineering resins including an ABS-like resin similar to that NZ based company that carried out some of our original prototyping and production, though to a higher resolution.
I have a small number of open wagons, vans and grain wagons available from stock, but I will be in the States visiting family and friends and won't be able to process orders from late June to Mid July.
https://jmdesignmodelrailways.com/blogs/news
The label clip and oval plate which our previous supplier struggled to print is now clearly defined.
GSWR van detail clearly defined few 'tell tale" signs of 3D printing.
A small number of CIE & GSWR Vans, Standard Open and GSR Bulk Grain are currently available from stock.
Unfortunately a batch of Brake Van bodies were badly damaged in the post and unusable.
  • Like 13
Decorated model of 15653 as an example of the standard of prints from our new supplier.
Although the painting was a bit of a rush job, the surface detail is nicely re-produced on all four sides of the wagon body with little of the tell-tale signs of 3D printing.
The body on this model was printed in what's described as a "tough-resin" the chassis in an ABS-like Resin which appears to have similar properties to our original print output.
  • Like 9
