New product for 7mm 5’3 modellers
One of the many advantages of the 3d print world is the ease with which designs can be tweaked for niche applications. A 36.75mm rerailer is about to come online from Chris-Draw. Ideal for bogie and 6 wheel stock, which can be tricky to put on the track. First drawing attached, and a view of the 32mm gauge product to show what it will look like. Obviously one for @David Holman, @Northroaderand @leslie10646 but others may be interested too….
  • Like 5
35 minutes ago, David Holman said:
A 21mm one would be good too, because proportionately wider body width make failing very tricky with bogie stock.
He’s very amenable. I just sent him a track sample and the B2B so it’s quite possible he could knock one up!
33 minutes ago, leslie10646 said:
Yes, one of each would be good, as I'm dual gauge!
Www.chris-draw.com is the place to go Leslie. He also does special long buffer magnetic couplings for Irish stock……;)
