leslie10646 Posted April 29, 2025 Posted April 29, 2025 Anyone done this? I have a power car to digitise, but I can't see how to get into it to attach the chip! Thanks in advance. There several on this forum, so someone must have done it? Regards Leslie
0 murrayec Posted April 29, 2025 Posted April 29, 2025 (edited) If this unit has been put together in usual SF manner, the body is glued to the chassis. Usually done with impact or UHU adhesives, so out with the scalpel and cocktail ticks to open it up- insert the scalpel in the join of body and chassis and carefully slide it along to try and cut the glue, as you proceed insert the sticks behind the blade as you move along. You may find molded parts in the join on the body side which will hinder the blade- their push-pull unit had four of these, 2 on each side, force will break these so go carefully....... You can see the broken moldings on the chassis edge here on the DVR I installed a NS angle at each end of the body with a captive nut soldered in, to screw the chassis back on, allowing for easy opening up in the future. Eoin Edited April 29, 2025 by murrayec 1 1
0 murphaph Posted April 30, 2025 Posted April 30, 2025 Eoin are those commercially available fibre optics or did you make them up yourself?
0 leslie10646 Posted May 8, 2025 Author Posted May 8, 2025 Thanks, Eoin. I send a query to John at Silver Fox as well and he replied impressively quickly. More recent BUTs from him come DCC-ready! He told me where to find the "ready" thingy and Lo and Behold - it was there ( under the "floor" in the centre of the power car). The nice man at Kernow selected a chip and had it DCC'd before you could say "Great Northern Railway" and a happy customer was in the car back to "Portadown Junction". I'll put up a video of the BUT set on the Dublin-based "Enterprise" when I've finished some "scenic" work (or my apology for it) at Portadown. Don't hold your breath! Thanks again! 1
leslie10646
Anyone done this?
Regards
Leslie
4 answers to this question
