UP6936 Posted May 26, 2013 Posted May 26, 2013 Hi there, one of my cravens has been listing over to one side a bit for a while. any ideas how to fix this? The coach still runs fine but it looks a bit odd in a rake of steady ones
0 WRENNEIRE Posted May 26, 2013 Posted May 26, 2013 Have you checked the bogies? They are a bit fiddly and can get a bit out of kilter at times Remove the screw and see if the coupler is correctly sitting in its depression The 2 lugs should be forward of the 2 retainers Spring should also be attached to the rear of the coupler Failing this get the rest of the coaches to lean to the same side and say nothing!
0 Flying Scotsman 4472 Posted May 26, 2013 Posted May 26, 2013 Hi there,one of my cravens has been listing over to one side a bit for a while. any ideas how to fix this? The coach still runs fine but it looks a bit odd in a rake of steady ones I will take a look at it the next time I see you. Had a couple of mine do the same. The problem can be fixed with a small piece of plasticard.
0 UP6936 Posted May 26, 2013 Author Posted May 26, 2013 thanks Anthony, glad there is an easy enough solution.
UP6936
Hi there,
3 answers to this question
