Warbonnet Posted September 27 Posted September 27 We love working with forward-thinking companies who bring fresh ideas to our wonderful hobby. From our locomotive driver packs from Modelu to our extensive DCC offerings from ESU, we enjoy great working relationships that add an extra dimension to our models. Now, we’re delighted to add another innovative business to that list, as we introduce exclusive load packs from our friends at True-To-Scale Models. Produced in the UK for Accurascale by Specialist Aggregates using long-term sustainable materials, these load packs are the perfect finishing touch for your Accurascale locomotives and wagons—or indeed, wagons and locos from other manufacturers. We’re launching with five different packs, with more to come depending on popularity. The first five packs 50g Mainline Coal The ideal finishing touch for your Accurascale steam locomotives and the Powering Britain range of coal wagons. Each pack contains enough material to fill one 4 wheeled wagon, multiple steam tank engine bunkers, or a single tender. 200g Mainline Coal This bulk pack is perfect for your Accurascale steam locomotives and the Powering Britain range of coal wagons. Each pack contains enough material to fill approximately four four wheeled wagons, multiple steam tank engine bunkers, or up to four tenders. 50g Cleveland Iron Ore A great choice for wagons used to transport iron ore. Each pack contains sufficient material to fill one 4 wheeled wagon. 200g Standard Grey Ballast Ideal for adding the finishing touch to your Accurascale MHA wagons, or any wagons used to transport ballast. Each pack contains sufficient material to fill four four wheeled wagons or approx two bogie wagons. 200g Light Grey Pennine Limestone Perfect for your Accurascale ICI Hopper wagons, ICI PO 21-ton Hopper wagons, or any wagons used to transport limestone. Each pack contains sufficient material to fill four four wheeled wagons or approx two bogie wagons. Availability These loads are in stock now and ready to dispatch. They are available exclusively through our website, and you can purchase yours via the link below: Order Your "True To Scale" Loads Here! View the full article 4
spudfan Posted September 28 Posted September 28 (edited) To make them go further you can put a cardboard base or polystyrene insert into the wagons and put the load on top of that. That is what I do with the Foster Yeoman/ARC tipplers. Just put a piece of card with the flaps bent downwards and spread the load on that. Put some sticky stuff on the card to hold the load material. I made inserts for some of the wagons from polystyrene. I just cut a lump to fit the wagon, painted it grey and covered it with ballast while the paint was still wet. Looks fine....I am not a rivet counter! Edited September 28 by spudfan 1
