GNRi loco wheel diameters
Class
J - Wheel Dia. 5' 7". Coupled wheelbase 7'1" ( O/A wheelbase 5'3" + 6' 4 1/2" + 7' 1")
P - WD. 5' 7". Coupled wheelbase 8'. ( O/A wheelbase 5'3" + 6'10 1/2" + 8')
P - WD. 6'7". Coupled wheelbase 8'. ( O/A wheelbase 5'3" + 6'10 1/2" + 8')
PP - WD. 6' 7" . Coupled wheelbase 8'3".  ( O/A wheelbase 5'3" + 6'10 1/2" + 8'3")
Q - WD. 3'2"/ 6' 7" coupled wheelbase, 8' 8" ( O/A wheelbase 5'9" + 7'6 1/2" + 8'8") Hate to say it (or my wallet hates to think of it) the closest donor loco for a Q Class is a Highland Railway "Loch" Class. It is almost perfect in all dimension apart from the 6' 3 1/1" driven wheels and a slightly longer cab..
QL - WD. 3'2"/6' 7". Coupled wheelbase 9'3"  ( O/A wheelbase 5'9" + 7'6 1/2" + 9'3")
S - WD. 3'2" / 6' 7".  Coupled wheelbase 7'6 1/2" + 9'6".  ( O/A wheelbase 6' + 7'6 1/2" + 9'6")
S2 - WD. 6' 7". Coupled wheelbase 7'6 1/2" + 9'6".  ( O/A wheelbase 6' + 7'6 1/2" + 9'6")
U - WD. 3'2" / 5' 9". Coupled wheelbase 8'3". ( O/A wheelbase 5'3" + 6'10 1/2" + 8'3")
V - WD. 3'2" / 6' 7". Coupled wheelbase 10'8" (O/A wheelbase 6'6" + 7'7" + 10'8". Tender WD. 3'8". wheelbase 6'6" + 6'6"
VS - WD.  3'2" / 6' 7". Coupled wheelbase 10'8" (O/A wheelbase 6'6" + 7'7" + 10'8".  Tender WD. 3'8". Wheelbase 6'6" + 6'6"
0-6-0
C - WD. 5' (*4'7"). Coupled wheelbase 7'2" + 7'10"
D - WD. 5' 1 3/4". Coupled wheelbase 7'3" + 8'3"
E - WD. 5'. Coupled wheelbase 7'3" + 7'9"
B - WD. 4' 7 1/2". Coupled wheelbase 7'3" + 7'3"
A - WD. 4' 7". Coupled wheelbase 7'3" + 7'3"
AL - WD. 4' 7". Coupled wheelbase 7'6" + 7'6"
PG - WD. 4' 7 1/4". Coupled wheelbase 7'6" + 8'1"
QG - WD. 4' 7 1/4".Coupled wheelbase 7'10" + 8'10"
LQG - WD. 4' 7 1/4". Coupled wheelbase 7'10"  + 8'10"
NQG - WD. 4' 7". Coupled wheelbase 7'10" + 8'10"
NLQG - WD. 4'7". Coupled wheelbase 7'10" + 8'10"
UG - WD. 5' 1". Coupled wheelbase 7'3" + 8' 4 1/2".  A class 2251 is very close in the running gear dimensions, Wheels are 1" smaller and the distance between 2nd and 3rd wheels are 1 1/2" closer. Boiler and smoke box isn't even close. A bit of 3D printing would sort that out.
SG - WD. 5' 1".  Coupled Wheelbase 8'1" + 8'10".
SG2 - WD. 5' 1".  Coupled Wheelbase 8'1" + 8'10".
SG3 - WD. 5' 1".   Coupled Wheelbase 8'1" + 8'10". Closest chassis i can find at the moment is a J39 , Coupled wheelbase 8' +  9'. Length of loco is similar but smoke box, boiler and cab is a fair bit bigger.
Crane Tank - WD. 3'4". Coupled wheelbase  5' + 5'
0-6-0T
BT - WD.4'7". Coupled wheelbase 6'6" ( O/A wheelbase 6' 9 1/2"" + 6'6')
2-4-2T
JT - WD. 5'7". Coupled wheelbase 7'1" ( O/A wheelbase 7' + 7'1" + 6'5")
4-4-2T
T1 - WD. 3'2" / 5' 9" / 4'. Coupled wheelbase 8'3" ( O/A wheelbase 5'3" + 6'10 1/2" + 8'3" + 8')
T2 - WD. 3'2" / 5' 9" / 4'. Coupled wheelbase 8'3" ( O/A wheelbase 5'3" + 6'10 1/2" + 8'3" + 8')
4-2-2
JS - WD. 6'7".  ( O/A wheelbase 5'3" + 6'8 1/2" + 7')
4-4-0 T
BP - WD. 4'7". Coupled wheelbase 7'6" (O/A wheelbase 4' + 7'3" + 7'6")
T - WD. 4' 7"
BT - WD. 4' 7". Coupled wheelbase 6'6" (O/A wheelbase  5'3" + 5' 10 1/2" + 6'6")
0-6-4 T
RT - WD. 4' 3"/ 2'8". Coupled wheelbase 7' + 6'6". ( O/A wheelbase 7'0" + 6'6" + 5' + 5'3")
2-4-0
G - WD. 5'7". Coupled wheelbase 7'1" ( O/A wheelbase 6'11" + 7'1")
H - WD. 6' 0 1/2". Coupled wheelbase 8' ( O/A wheelbase 7' + 8')
2-4-2T
JT - WD. 5' 7"
0-6-2T
QGT - WD. 4' 7"/ 3'7 1/2".  Coupled wheelbase 7'6" + 8'6".  ( O/A wheelbase 7'6" + 8'6" + 6')
QGT2 - WD. 4.7 1/4" / 3'8". Coupled wheelbase 7'6" + 8'10".  ( O/A wheelbase 7'6" + 8'10" + 6')
0-4-0T
No. 203 - WD. 2' 8 1/2"
0-4-2
K - WD. 5'1". Coupled wheelbase 7'2" ( O/A wheelbase 7'2" + 6'10")
0-4-2
F - WD. 5'. Coupled wheelbase 7'9". ( O/A wheelbase 7'9" + 6'11")
Edited by Moogie-69
It’s probably worth adding the coupled wheelbase and overall length to the listings; these also need to be reasonably close for a model to look plausible.
Also a note on cylinders and valve gear (inside/outside etc).
As far as the models are concerned, older models are more likely to have a separate chassis which can be fitted into a replacement body. New models with a lot more gadgets often have much more integration between body and chassis, so are less easy to modify.
  • Agree 2
