FrankS Posted May 30, 2012 Posted May 30, 2012 Hi all, I now have (or soon will have) 6 Murphy Models 141/181 Diesel Locos. I understand that these have a 21-pin decoder socket. Can anyone please tell me what is the recomended PlugmPlay decoder & harness and where can I get it ? Is there plenty of room in the loco ? I like TCS decoders from the USA but want to make sure it will fit in. NB - Ordinary decoders NOT sound. Thanx, Frank Savery Quote
0 aramand Posted May 30, 2012 Posted May 30, 2012 These are the ones I use : http://www.ehattons.com/21213/Bachmann_UK_36_554_3_function_2_sided_1A_decoder_with_21_pin_plug_and_back_EMF_for_slow_running/StockDetail.aspx simple to fit once you have the body off, I think its better to go with one without the harness as fits directly onto the pins in the loco. Quote
0 irishthump Posted May 30, 2012 Posted May 30, 2012 simple to fit once you have the body off, I think its better to go with one without the harness as fits directly onto the pins in the loco. I would agree, a harness would get in the way with the limited space inside the narrow body. Here's a TCS 21 pin without a harness, should do the job. http://www.dccsupplies.com/shop/product_info.php?products_id=4721 I recently picked up another 141 and decided to just put a non-sound decoder in it. (My other 3 141s are all DCC sound chipped.) I ended up using a Hornby Sapphire that I had lying around, works fine.More expensive than the Bachmann, but I think it has a few extra programming features. Quote
0 Flying Scotsman 4472 Posted May 30, 2012 Posted May 30, 2012 You will have no problem fitting a TCS decoder into the 141/181 with or with out a harness. I've just fitted an 8 pin sound decoder/8 to 21 pin converter and a bass reflex speaker for a site member a very tight squeeze and some modifications were needed to the body and chassis but its all in there. All my own 141/181's use a 8 - 21 converters and decoders with harnesses I don't use the Bachmann decoders as they don't support CV 19 so no good for double heading unless you give both locos the same address. Quote
0 djkonore Posted June 3, 2012 Posted June 3, 2012 I have a TCS decoder fitted in one of my 141/181's. It's the "euro style" as they call it, 21pin decoder. (no harness), fits just fine, same as any 21pin decoder. It's a nice smooth silent runner. Quote
0 FrankS Posted June 4, 2012 Author Posted June 4, 2012 Thanx for the info, guys. VERY much appreciated. I've put in an order to DCC Supplies for the TCS units. Cheers, Frank Savery, Tasmania Quote
0 Joe Keegan Posted June 4, 2012 Posted June 4, 2012 Hi Frank Richard Johnson of DCC Concepts in Aus is a TCS dealer,it might be cheaper and quicker delivery. If you still looking for a DCC system , I would strongly recommend the NCE Powercab which is fully expandable. Big Plus is that the Powercab it is Fully MNRA compliant.Have a look at their web site. Regards Joe Quote
0 Guest hidden-agenda Posted June 4, 2012 Posted June 4, 2012 (edited) Gone be the days when you bought a Hornby set and put the two Ever ready batteries ( remember the ones with the big spring contacts ) into the plastic controller and away you went. Edited June 4, 2012 by hidden-agenda Quote
0 Joe Keegan Posted June 4, 2012 Posted June 4, 2012 Gone be the days when you bought a Hornby set and put the two Ever ready batteries ( remember the ones with the big spring contacts ) into the plastic controller and away you went. Great days okay but now we have Murphy Models 141's , 201's and now even better days with more choice LOL Enjoy your day, Regards Joe Quote
0 Flying Scotsman 4472 Posted June 4, 2012 Posted June 4, 2012 Gone be the days when you bought a Hornby set and put the two Ever ready batteries ( remember the ones with the big spring contacts ) into the plastic controller and away you went. Now your just showing everyone how old you really are. Quote
0 Guest hidden-agenda Posted June 4, 2012 Posted June 4, 2012 Now your just showing everyone how old you really are. Hello Joe and Anto your catching up with me. Quote
FrankS
Hi all,
Thanx,
Frank Savery
10 answers to this question
