1/96th scale R/C Mustang.
Fancy a flying aircraft for your layout? This one is just a little under-scale.....
Incredible miniaturisation. I have the paper plans for a 1/5th scale P51 (Ziroli plans) to be powered by a Zenoa 62cc petrol engine. Need to finish the B25 first.
'tis crazy, innit..?
Must be nearly impossible to video in flight.....
Well I guess the power to weight ratio is interesting so she probably flies at quite a high airspeed due to high Vs. Would love to see it in flight though. I presume it could only successfully operate if indoors in still air.
This is a slightly smaller one - not easy to keep your eye on it.....
..might be worth trying it full-screen..
Wow. And she's flying at a scale speed of mach 0.82 :) But the first one you posted seems incredible to get elevator, ailerons, rudder, throttle, flaps and retracts is just nano engineering at its best.
