Garfield Posted April 20, 2012 Posted April 20, 2012 1. Go to the image host's website (TinyPic is good and easy to use). 2. Click 'choose file' and select the image you want to use and click 'open'. 3. The file name will now appear in the appropriate field. Click 'upload now'. 4. In the pop-up window, fill out the 'captcha' security code and click 'upload now'. 5. Once the image is uploaded, you will be given a number of link options. Select 'IMG Code for Forums and Message Boards' and copy the code. 6. Paste the code into your forum post and you're ready to go!
BosKonay Posted April 20, 2012 Posted April 20, 2012 it's worth a mention that you can directly upload up to 2MB in size, and 1024x760 pixels in dimension images to the site or your site album here also if needed. Use this method if you are having trouble with uploads or your files are too large!
