Basic Colour Light Signal set up
Hi.
As a complete electrics novice, l hope someone can help!
I'm looking to set up from scratch, a set of 8 Colour Light Signals on my layout (4 × Three Aspect Colour Lights & 4 × Ground Position).       All supplied by CR Signals- seem to closest resemble lrish Rail ones.
I have a Hornby Select DCC but am happy to manually switch the lights as required at this point.
Trouble is l am a complete novice on the electrics side & can't seem to actually identify what exactly l will need to start up.
I guess:
4 Changeover SPDT switches for each of the Ground Position.
4 Three Position Rotary switches.
(If so any suggestions, on each?)
I read if l was working one signal, l would need a 5 - 12v DC supply-   if l am running 8 signals, do l need 8 of these?
Ideally is there one overall controller that could handle these 8 signals but if not, if l was running them individually, what is best?
Hope l get some help here and bear in mind, l am a novice on the electrics so would love to know what l actually physically need to have!
Thanks in advance.
Rob.
PS l did try to locate similar answers here before posting but couldn't find the specifics.
1 answer to this question
Hi Rob.
I use Train tech running and shunt signals on Tara junction
I find them very easy to set up and use with my DCC system, I am like yourself a novice with the electrics, but the Train tech signals work for me.
Answer this question...
