DART8118 Posted May 20, 2019 Posted May 20, 2019 It was by the south embankment wall just outside Westland Row station. Sorry about the quality of the image. Many thanks in advance. DART8118
0 josefstadt Posted May 21, 2019 Posted May 21, 2019 I think that it is the back of a miniature / shunt signal. 1
0 DART8118 Posted May 21, 2019 Author Posted May 21, 2019 16 hours ago, josefstadt said: I think that it is the back of a miniature / shunt signal. Many thanks for that josefstadt. Makes sense in the context of the old OS map which would suggest a righthand turnout ahead. I also have a copy of a DW&WR terminus diagram by McKenzie & Holland of Worcester. These are both of the same timeframe and I wonder now if that would be the maker's name at the bottom of the image. Unfortunately, other photos don't seem to include it. Must keep searching.
0 Mayner Posted May 22, 2019 Posted May 22, 2019 17 hours ago, DART8118 said: Many thanks for that josefstadt. Makes sense in the context of the old OS map which would suggest a righthand turnout ahead. I also have a copy of a DW&WR terminus diagram by McKenzie & Holland of Worcester. These are both of the same timeframe and I wonder now if that would be the maker's name at the bottom of the image. Unfortunately, other photos don't seem to include it. Must keep searching. The GSR introduced power signalling on the Amiens St-Dunlaoire section during the 1930s with a elevated signalbox at Westland Row. Signalling was using fullsize & miniature searchlight signals commonly used during the 1930s, pointmotors and signals were possibly supplied by Westinghouse Brake & Signal Company in the UK. http://briansolomon.com/trackingthelight/tag/searchlight-signal/ http://catalogue.nli.ie/Record/vtls000305055 1
0 DART8118 Posted May 22, 2019 Author Posted May 22, 2019 Thanks John for the info and for pointing out that photo. I can see at least 2 others in that. Following up on your reply and the earlier one from josefstadt I've revisited the NLI image at http://catalogue.nli.ie/Record/vtls000306673 and I can now see another of the same type. This one would also be at the approach to a facing righthand turnout. Thanks for the great advice. Have to keep searching now to find a detailed image. 1
DART8118
DART8118
4 answers to this question
