Everything posted by patrick
My previous post is a series of pictures following a typical operating session on the layout. We imagine the action taking place during daylight hours in early October at the start of the beet season. The second photo, which is out of sequence, shows the Cork fiddle yard at the start of the session. The empty beet train takes the loop at Grange to wait for the Waterford Cork Bell liner and once that is clear swaps an empty beet wagon for a loaded one before continuing to Glen More, passing loaded wagons at Keilys Cross which will be picked up on the return trip. Meanwhile the Waterford Cork goods takes the main line at Glen More to wait the arrival of the beet special. To be continued...........
A marvelous piece of work. I am impressed at how much you get done so quickly.
A wonderful layout in the making. Looking forward to seeing more posts.
I suggest assembling a short section of track including a point or crossover on a piece of plywood and a couple of wagons to test the waters. The Dapol tank wagon kits mag be a good choice since they are inexpensive and if all went well can be detailed with the SSM detailing kit. John Mayer posted some information on this conversion somewhere on the site. If all goes well convert a loco and take it from there. As regards high/eye level baseboards, set up a section of track some rolling stock and some vehicles figures or structures on a high shelf and see for yourself how effective this approach is.
I am sure that as soon as a large selection of high quality Irish models are available ready to run we will finally see some incredible layouts from certin members on this site. In the meantime I suggest lighting a candle rather than curse the darkness.
Re previous post, just trying to figure out how to post photos from my phone.
steverabone.com/RailwayPhotographs/unknown_irish_photographers.htm Some great late 60's scenes.
I just noticed I posted this link before a few years ago! I tried to post another link to some 60's and 70's photos which I have bookmarked but the link no longer works.
sutherland.davenportstation.org.uk/ws-189.html
My concern is about mixing body mounted couplers with bogie mounted couplers which cause problems on curves epically when pushing rolling stock through points during shunting movements. A bracket on the end of the bogie frame with provision for mounting a cupler pocket would be perfect.
Any plans for a coupler mount on the bogies?
Thanks Garfield. The Rathkeale one was installed in the late 60's. Presumably they all date from this period. I'm surprised to hear there is one still in use at North Wall.
Train length was a major consideration when designing the layout. A secondary main line theme was chosen because 4 coach passenger trains would not be out of place and that became the maximum train length. Remember trains have to fit into two staging yards and two passing loops so for every additional unit a train is increased by four units are lost from the main line. A long run between stations was desireable as I like to see trains run through open country as much as shunting. When the layout was extended on the West (Cork) end, the Cork staging yard ended up much longer. This was not intentional but as a result of having to fit the yard throat around a curve and this was the only way I could get it to work without building custom pointwork. At present train length is limited by Waterfor staging yard and Grange passing loop which have a capacity of a locomotive and 11 20 foot wagons or 4 coaches. Longer trains are run but this involves some fiddLing at Waterford staging yard or in the case of loose coupled goods trains, ensuring that they arrive at Waterford with less than 12 wagons and a brake van. On the list of things to do is to install curved points in Waterford staging yard to gain a few inches in train length. Regarding the dolomite train, 12 wagons are visually too few for a pair of GM's. The photos were staged to suggest how the prototype was run. An A class will be employed during regular operating sessions.
The Irish Railway Models ballast wagons finally arrived to this part of the world this week and we're put into service masquadering as dolomite wagons. The models are just fantastic, I cant add anything to the justified praise which they have received. Dolomite deposits exist near Rathmore on the Tralee line and in my alternative history it was shipped to Ballinacoutry over the South Waterford line. Future plans are to build a couple of older style plough vans appropriate for my 1973-74 era. Ballast was loaded at Carroll Cross at various times which would justify frequent ballast trains on the layout.
There has not been much progress on the layout in the last few months due to home renovations and a vacation in Florida. The layout has been operated very frequently though. We now have enough opens to run a decent size beet special over the line. This train is a lot of fun to operate running from Cork fiddle yard to Glen More and back swapping loads for emptys along the way.
