Fowler4f Posted August 14, 2021 Share Posted August 14, 2021 I replaced the tension lock couplers on MM 1508 with Kadee No.20, the swallow tail is approximately 2mm short. Is there a Kadee solution to this problem ? Or will I just “weld” a No.20 in position with Superglue ? Thanks Quote Link to comment Share on other sites More sharing options...
DiveController Posted September 25, 2021 Share Posted September 25, 2021 Some solutions here maybe https://irishrailwaymodeller.com/topic/6787-kingsbridge-kadee-coupling-conversions/?tab=comments#comment-110987 1 1 Quote Link to comment Share on other sites More sharing options...
murrayec Posted September 25, 2021 Share Posted September 25, 2021 On 14/8/2021 at 6:48 PM, Fowler4f said: I replaced the tension lock couplers on MM 1508 with Kadee No.20, the swallow tail is approximately 2mm short. Is there a Kadee solution to this problem ? Or will I just “weld” a No.20 in position with Superglue ? Thanks The pocket on these coaches is to high! As you suggest, super glue it to the underside of the pocket and your almost at the right level!! Eoin 1 Quote Link to comment Share on other sites More sharing options...
Fowler4f Posted September 27, 2021 Author Share Posted September 27, 2021 On 25/9/2021 at 9:52 PM, DiveController said: Some solutions here maybe https://irishrailwaymodeller.com/topic/6787-kingsbridge-kadee-coupling-conversions/?tab=comments#comment-110987 Apologies for slow reply, Thank you for posting, food for thought. Quote Link to comment Share on other sites More sharing options...
