Warbonnet Posted February 2, 2023 Posted February 2, 2023 Our Class 31s have been warmly received since they were announced just under 12 months ago. Our main range has been flying off the shelves at pre-order stage and we are about to enter production in the coming weeks. Everyone also knows that we like a couple of "Accurascale Exclusives"; or series of special edition locos available only direct from our website, open to all without the need for club fees and fair prices that are in keeping with our main range. So, it's about time we revealed our Accurascale Exclusives Class 31s! PRE-ORDER YOURS RIGHT HERE! First up is 31407 in the elegant Mainline Freight livery Second up is 31466 in the the striking colours of EWS Both locomotives capture that mid 1990s era, which was one of great change for Britain's railways as privatisation commenced, with a plethora of colourful liveries adoring heritage stock as new companies made themselves known. It was also the twilight of many Class 31s, as they were withdrawn and stored with the advent of the Class 66 in the late 1990s and they became life expired. This pairing makes up one half of our Accurascale Exclusives Class 31 range, with another pair to be announced soon. They also follow our main range with an industry leading specification; - Highly-detailed OO gauge model, 1:76.2 scale on 16.5mm track- Minimum Radius 438mm (2nd Radius Set-track)- Die-cast metal chassis- Bogie with separate footsteps, brake cylinders, speed recorder and end brake rigging- RP25-110 profile OO gauge wheels- Brake blocks on bogies in line with wheels- Scale width wire handrails- Etched metal/plastic detail parts, incl. grab handles, steps, wipers, etc.- Etched metal roof grille- Etched metal pre-painted nameplates, plaques and arrows (if applicable)- Accurate high-fidelity miniature snowploughs- Full underbody battery box/air tank detail with pipework- Fully sprung buffers, multiple pipework variations and screw couplings- Kinetic NEM coupler mounts at correct height with mini-tension-lock couplers- DCC ready [21-Pin MTX Socket] or Factory-Installed DCC Sound options- Two quality speakers with large sound capsules for best possible sound (DCC Sound models only)- Wheel flange squeal sensor on DCC sound fitted locomotives- Working radiator fan, driven from separate motorHigh Performance traction, to include;- High quality 5-pole motor with two large flywheels- Helical Gear box for maximum performance and slow speed running- Gearing arranged so locomotive can achieve a scale top speed of 90 mph (145 km/h)- DCC ready with PowerPack capacitor for uninterrupted power- Outer axles on bogies are driven (sprung dummy centre axle) and all wheel pickupFully detailed Lighting Pack, including:- Directional lighting, DC and DCC- Switchable Red and white marker lights (red can be switched individual lights or both on)- Separately switched cab lighting and illuminated, driver’s desk with auto/off on movement These two locomotives will enter production after our main range and arrive in stock in Q1 2024. They are priced at £169.99 DC/DCC Ready and £269.99 DCC Sound Fitted. Both are only available direct via our website and you can pre-order by clicking here! View the full article 1
