Revolution Trains OO SR Inspection Saloon
is it the angle or is there some sort of issue with the scale?
Any photo i’ve ever seen the car is smaller than the loco. this looks like someone has the photocopier set to 110%?
It does sit a bit high on the bogies.  Apparently there are plastic shims that are fitted between the bogies and the chassis - presumably to enable transit around R2 curves.  Removing the shims is supposed to improve things a tad height-wise.
Cheers
Darius
