Darius43 Posted January 17 Posted January 17 (edited) MTK LMS corridor brake coach kit built as a UTA (ex NCC) coach. Repainted Dapol LMS suburban coach. Plus an MPD… Cheers Darius Edited January 24 by Darius43 16
Darius43 Posted January 19 Author Posted January 19 Another Dapol suburban coach repainted. Cheers Darius 7 1
Patrick Davey Posted January 19 Posted January 19 Lovely work Darius - how do you get the thin yellow waist line so fine and so straight? 1
Darius43 Posted January 19 Author Posted January 19 Hi Patrick, I use HMRS pressfix lining decals. You cut out and peel the lining away from the backing sheet and place it sticky side down where you need it. After that you apply water with a brush to the tissue paper covering and peel it off leaving the lining in place with no carrier film. It’s a lot easier and much less stressful than using waterslide decal lining. You can make sure the lining is straight and in the right place before applying the water. I used pressfix lining for this Ratio LMS coach. Cheers Darius 3 1
Darius43 Posted January 24 Author Posted January 24 Some more UTA coaches - MTK corridor 3rd and repainted Bachmann LMS coach. Cheers Darius 7 1
jhb171achill Posted February 26 Posted February 26 On 19/1/2025 at 8:08 PM, Patrick Davey said: Lovely work Darius - how do you get the thin yellow waist line so fine and so straight? It looks great - though, straw rather than yellow - and (while probably impossible to replicate in 00 scale) it was only a on-inch straw line, and worse, edged both sides in a 1/4 inch red line! The RPSI's Mk 2 livery lining, with a yellow line, and a single, separate red line, was based on the notion that this livery should not be actual UTA, but should look reminiscent of it on dark green carriages. Thus, the RPSI's own livery, with yellow replacing straw, and different thickness and style of lining. But I digress! Darius - as always - truly amazing work. That Dapol yoke looks just like the aluminium-clad "upgrades" of old (originally panelled) NCC stock in the 1960s. 1
Darius43 Posted August 6 Author Posted August 6 Two more Bachmann LMS coaches repainted and decalled. Cheers Darius 6
