MDF Vs. Plywood
As a carpenter of many years and Carpentry Instructor I was never a fan of MDF however our local timber supplier sells Chinese made plywood that is sub-standard and the veneers are prone to peeling after cutting. There seems to be no glue between the layers. I've steered clear of it at all time. I know the pro's and cons of an mdf baseboard but is there any one on the forum who could comment on whether or not they experienced any REAL operational problems with it?
I'm thinking of building a 6'x3' N-gauge layout and considering 12mm MDF on 12mm x 70mm battens - is this adequate?
@GNRi1959, my baseboard is made of 18mm MDF and I have never had a problem with it moving/ shrinking/ swelling or warping. It is based in a room in my home so not exposed to conditions that would come with it being in a loft or shed. The frame under is 70 x 30 red deal (probably overkill). But to answer your question , no I have never had any problems with MDF. I wouldn't use WBP (water bonded plywood). It warps like crazy and actually it is never flat from day one in my experience. In my opinion the use of 70x12 battens on edge sounds okay if you use enough cross members. Hope this helps (I'm in the same game by the way)
Derek
Thanks Derek, l opted for 12mm birch ply which will be fixed to a 69 x 12mm timber frame. This should be sufficient and not too heavy.
