MRHD's Workbench.
Hi All
I got a gift of an airbrush for Christmas and I have been experimenting with it to get the hang of it.
I started off using Humbrol enamels but I struggled to get a decent finish. Then I discovered Vallejo acrylics and I am much happier with them, at least until the skill level increases.
I also started off using the car body aerosol primer but again I was disappointed with the results. Then I came across the Vallejo coloured acrylic primers while watching the ScaleModelMedic channel on youtube and I found them much easier to use.
Anyway with all this practice I said it was time for a project or two
The first thing I decided to attempt was a 'make-over' for my Hornby track cleaner
This is what it looks like out of the box Hornby Track Cleaner
This is what mine looks like after a few false starts
So with a little confidence I decided to convert a second hand BR Class 29 I have (collectors look away now). All my rolling stock is IE Diesel, so the BR livery is a bit out of place. I decided to try my hand at IE-Freight Silver and Black. The long term plan is to respray some MKIIIs to suit my 141/181 and 201 Locos.
After cleaning it down I gave it a coat of primer
Then I gave it a coat of black, from some reading I have been doing since I should really have started with the lighter colours
My next task is to mask it up and spray the yellow warning panel.
I have been reading, that to stop paint bleed, I should give it a light spray of the black over the masking tape before spraying the yellow. Should that black be allowed to dry completely overnight or can I let dry for 10-15 minutes before spraying the yellow.
Hi BosKonay
Its a Badger Renegade-Velocity. It has a really fine needle which I managed to get blocked a good bit in the beginning but I am getting better with the cleaning and paint thinning.
  • 3 months later...
After a bit of a delay caused by a bad choice in masking I am finally making some progress again
I have the warning panel and the silver cab ends painted. Next is to try the orange lining
