Build Nir 450 castle class
Hi there, I have seen some decent 150 re paints to make them look like a 450, but if you want something more accurate, worsley works do a brass kit for the 450 class, apart from mentioned I haven't seen anyone bash a 450 class before.
Very time consuming to convert from donors eg 150 class units and these being underfloor powered you would need to re-power and keep underframes clear for brake gear etc.
As Nelson says a 450 class brass kit from worsley works is easier to build and can be completed within a very short time frame too...
Here is one I made from a Dapol Class 151/2 some time ago.
But it would not touch a Worsley Works kit, but a lot easier to make.
Good luck on your build.
